This version 2016.2.5 is the new major version that also has been validated at DARE!! Measurements. We however strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The following issues are fixed in this 2016.2.5 version (compared to the 2016.1.12 version):
- #6304: Reference level should be requested to ensure a correct calculation of the measurement value
- #7437: R&S FSEK 30: Function not available;BAND:MODE:FFT OFF
- #7468: Quasi peak measurement of Analyser sometimes has a difference
- #7634: R&S FSEK 30: Function not available: FFT OFF
- #7786: Regular expression of RFS2006B antenna tower is incorrect
- #7787: Driver Vectawave VBA230-22 and VBA1000-150
- #7789: Advantest TR4172 Not all bytes are written to the GPIB-Board within the timeout period
- #6218: TSF description inside a SEQuence is changed to No Description
- #6634: Project: Voltage dips and interrupts
- #7004: Pasting large data (19000 rows) into a COR file is crashing RadiMation
- #7018: System error is not included in the Report Error
- #7026: Closing the adding of a short cut key is still adding the entry
- #7027: Save as test equipment buttons are incorrectly alligned
- #7029: RS232 communication method available for the Keysight N9038A while the device does not support it
- #7060: Changing a value in the Advanced Options grid, resizes the columns to very small
- #7121: The attenuation in MB Emission shows: Auto (100 dB)
- #7122: Layout of CE Multiband TSF is strange
- #7150: VDI: ReducedVoltageTime not marked in seconds
- #7152: VDI: Adding EMtest VDI driver.
- #7153: VDI: Remove workaround in device driver Keytek
- #7154: VDI: Repeat count
- #7155: VDI: Repetition time is not passed to the driver yet.
- #7157: VDI: Only show available line couplings.
- #7158: VDI: Debug EMTest UCS500N VDI driver on the device itself until it works.
- #7160: VDI: LineCoupling ignored error when starting test
- #7162: A strange symbol as digit seperator is not used in the interpretation of a string
- #7164: VDI: Phase Angles
- #7165: Repetition count
- #7166: SurgeMB phase angle cannot be selected
- #7172: VDI: ReducedVoltageTime not marked in seconds
- #7186: VDI: Reopening VDI with multiple bands shows unable to start error.
- #7527: Include ADVANCED.INI and TUNING.INI in an error report
- #7530: Selecting 'AD converter selected in testsite' as monitoring input device is default selecting 'nothing' instead of channel 1 resulting that nothing will be measured
- #7540: Channel numbers are all default set to 0
- #1688: Cannot save multiband test
- #3398: Test on hold when opening RE Multiband file
- #4074: Optimize angle is not measuring every area
- #4155: Device specific parameters are not retrieved when a device driver is created
- #4714: Cable loss correction applied to the Cable antenna Preamp is incorrect
- #4771: Adding cable with default port type value is not correct
- #4800: Comparing test data and zooming graphs in Multiband is not working
- #4823: CORrection factor current probe is not taken into account
- #4855: Possibility to directly open device driver TYPE window and TAB by just one click
- #4892: RM crash during RPR2006P Free mode when test equipment is opened
- #5222: Add a Virtual Instrument for the Amplifier
- #5223: Add a Virtual Instrument for the Signal generator
- #5270: Peak conservation setting is ignored for Singleband Radiated Immunity
- #5368: Graph data is not updated
- #5550: Add an 'Configure...' menu entry in all the sub-menus of the Devices menu
- #5565: Opening the virtual powermeter window shows a corrupt file error
- #6130: Device driver: emtest VCS 500
- #6228: Cable correction is not correctly taken into account during the Current Probe test
- #6421: Multiband graph is not exporting vertical and/or horizontal polarization graph
- #6667: Virtual Instruments should be able to collapse to a 'mini' mode that only shows the measurement value
- #6703: Driver: em test PFS 500
- #6704: Driver: em test MV2616
- #6705: Driver: emtest UCS500N5: voltage dips and interrupts support
- #6745: Include a 'Clear' button on the VI Fieldstrength sensor to clear the (time-)graphs
- #6746: Lower and upper value of the analog meter on the VI should be autoranging
- #6747: Show the 'table' tab for the time-graph in a virtual instrument
- #6749: Time graph in Virtual Instrument is using the wrong date
- #6750: Time graph of a Virtual Instrument should have a minimum time range of 30 seconds
- #7040: Marconi signal generator doesn't respond on *STB?
- #7065: A MB emission test shows a 'Fail', even if all emissions are below the limit
- #7102: Backwards sweeping is not correctly handled
- #7151: VDI: ProgressBar starts at 99%
- #7202: Longer time till sleep mode Narda EP600/EP601
- #7205: Default settings of Multiband EFT is not logical
- #7206: Default settings of Multiband Burst is not logical
- #7210: emtest PFS 500N Not all bytes are written
- #7213: Sequence are shuffled
- #7230: VIBase not always (dis)connecting
- #7231: Add suggested values
- #7234: Unit window showing example of setted settings.
- #7235: Clear Graph button in the VIBase is not correctly implemented.
- #7239: Unable to clear graph in VI windows while trigger is set to auto.
- #7250: Unit settings example is not correct with a precision of 0
- #7251: Unit settings applied to AnalogMeter control before init
- #7276: Unit settings are applied on fieldsensor not on the ctlAnalogDigitalMeter control itself.
- #7307: Error messages in the VI Powermeter are not shown
- #7327: Not controllable EFT and Surge device drivers should raise an error, early at the automated test
- #7328: Multiband EFT Test is in a continuous loop, when an error is raised
- #7335: Determined Forward power step during amplifier linearity is 100000 dB
- #7360: Calculated graph is recalculated 6x when an additional non-relevant graph is shown
- #7363: VIBase not always (dis)connecting
- #7364: 'Clear' button is hidden when the VI window is resized when the device is disconnected
- #7366: Resizing of 'Logging' tab of VI Powermeter is not done when another tab is active
- #7367: Tabs on the VI Powermeter should be hidden when the size of the window becomes too small
- #7368: Hide the analog meter if it becomes too small
- #7369: Improvements for the VI Turntable window
- #7370: Allow smaller size of VI Antenna tower
- #7371: A VI window should remember it's location and size
- #7373: RadiFree warnings
- #7374: Location and size of the window is not remembered if the RadiMation main window is closed with windows open
- #7375: Settings of the VI Signal generator are not set in the signal generator after a connect
- #7376: Clear button of a VI should also be enabled when the device is disconnected
- #7377: Clear button should be pressed automatically when the VI window is closed
- #7378: Only show the test initialization window if it contains more than 1 item
- #7380: Auto-Show and Auto-Connect for VI devices
- #7388: Resizing of the contents of the VI Powermeter window is incorrect
- #7389: Virtual Instrument window of the Virtual signal generator is always showing disabled controls
- #7391: Improve the showing of the 'Devices' menu
- #7396: RadiMation crashes during start with open automatically connecting VI windows
- #7410: Saving a test equiment with changing just 1 char to uppercase seems to overwrite the existing test equipment
- #7413: Unit Volts per meter shows only V
- #7417: Validation documentation of RadiMation
- #7429: Correction of Monitoring Input powermeter is also applied to the used (forward) powermeter during the test
- #7442: Invisible Clear Button
- #7443: Visible progress bar
- #7446: Reflected powermeter measurements data is incorrectly shown
- #7452: Improve the showing of the "Test-Site Menu"' menu
- #7453: Device menu also contains an Add Device button
- #7458: Address Information will pause a running test
- #7464: Name the log file the same as the subject description instead of always Last error report
- #7470: VI Signal Generator Carrier ON and OFF control has incorrect triggering
- #7507: Graphs are not drawn when 'Ramp' method is used in MB Immunity
- #7512: Virtual burst powermeter doesn't work anymore in RadiMation Free 'Burst' mode
- #7529: New testsites are shuffled in the Test-Sites list
- #7598: Error report, customer information is not remembered
- #2079: Usage of Amplifier protection is not clear if correction file has wrong columns
- #2631: Changing the minimum attenuation value argument in the device driver is changing the set attenuation
- #4209: No frequency verification on correction file
- #4380: CI multiband: crash during changing the band
- #5071: N9010A is not recognized anymore Unknown system error
- #5505: Rounding issues of Correction values (COR) when copied to clipboard
- #5515: Different measurement results with Singleband and Multiband test for Fixed Power method
- #5647: Correction file doesn't allow logarithmic interpolation of the value
- #6101: Disable all menu and editable items of which an engineer has no rights
- #6736: Correction is remembered in Virtual Instrument Powermeter when the correction file is detached again
- #6984: Infinite regulation when amplifier is in noize region
- #6987: RadiLog in 64 bits
- #6996: Peak numbering for emmission measurements are not shown and can't be sorted
- #7015: Radiated Immunity variable power closed loop with current sensor is endless regulating at first point
- #7159: RadiLog crashes with out of memory during a big test
- #7161: 7th point in RI calibration
- #7288: RadiLog slow with big description
- #7393: 'Output boxes' is shown as 'Unknown device driver types' in the 'Devices' menu
- #7445: Reflected powermeter measurements are not corrected
- #7533: Multiband Ok button of 'Continue automatic mode settings' is disabled
- #7555: Duplicate other test description menu in the graphs menu
- #7579: Copying the information of the EUT Monitoring grid to clipboard causes crash
- #7581: Test description of the test is not visible in the test data
- #7594: Radilog Deleted log when closing test
- #7595: RadiLog cleared within sequence
- #7569: Usefull RadiLog default description when sending an error report
- #7597: RadiLog Error Report disappearing window after sending log
- #7617: Cancelling the closing of the VI Fieldsensor results in a not working window
- #7618: Export of time-graph doesn't export all the data
- #7621: Exporting Report Generator using different extentions for template as the output, causing error cannot open file
- #7627: Endless regulation at frequency point during RI Fixed power test
- #7649: ReportGenerator to much capital letters
- #7660: Adjusted Fieldstrength units are not used in the scaling of the VI graphs
- #7663: CONFDVDR deadlock when Access to the path (..) is denied error is raised
- #7688: Correction data is not correctly determined from unsorted correction file
- #7691: Exporting graph to LLF doesnt show the in graph
- #7692: Copying the EUT Monitoring table to the clipboard causes a crash
- #7719: Exporting AD channels
- #7725: Multiple cosmetic changes to prevent controls from being hidden when window is resized
- #7726: Unicode: EUT files with chinese characters in the filename are not loaded correctly
- #7729: RadiLog doesn't show full binary data strings
- #7734: Report Generator code Step Frequency for ConEmi absorbtion clamp
- #7735: Unicode: INI files in unicode
- #7748: Unicode: Test-Sites
- #4132: Minimum performance with pulse modulation not working correctly
- #6301: Preamplifier setting is not visible anymore in the CE MB TSF window
- #7428: Load XML error at RadiMation Startup
- #7640: Crash during startup due to newer CUSTOMIZ.XML
- #7714: Unlogic that the (activated) Monitoring input channels are used during Radiated Emission
- #7758: Error is raised that columns contains 3 columns, even if only 2 columns are present
- #7765: Error the maximum recursive read count has been reached during startup
- #6109: Incorrect AD measurement after AD channel settings are unexpectedly changed
- #6127: Older TSF file with minimum performance limit is not working anymore and is crashing the software
- #6128: Small dips in negative singleband Emission results
- #7635: Error access to the path (..) is denied after Network Analyser Calibraton
- #7650: Voltage test level Voltage measurement (Powermeter) is not measured
- #7770: Removing Test level from RI MB is closing the test and also gives error
- #7774: Correction of resistor is not used in magnetic field measurement
- #7788: Environmental data window can be shown behind mainwindow
We also include several improvements and new functionalities in version 2016.2.5, the most important improvements are:
- Automated test for Voltage, Dips and Interrupts.
- Improved RadiLog communication monitoring.
- Better checks of used correction files.
- Virtual Instrument control for Field strenght sensors, signal generators, turntables and antenna towers.
- Several user interface and usability improvements.
- Report generator fixes
- Better control of measurement equipment.
The new 2016.2.5 release of RadiMation can be downloaded from the DARE!! web-site:
