The new 2017.1.5 release of RadiMation can now be downloaded from the DARE!! web-site.
We already are aware of 1 known issue in this version:
- During a multiband emission test it is possible that an 'Outside points' error is generated. (#8062)
The following issues are fixed in this 2017.1.5 version (compared to the 2017.1.4 version):
- #7633: Unexpected oscilloscope measurement value of first frequency point
- #7652: Configurable Injection Device custom frequency range is not retained
- #7901: ControllerDelay for a GPIB controlled Maturo MCU can be 0
- #8092: When a printout is generated and printed the 'busy' dialog should be shown, to indicate that the PC is busy
- #8113: Unable to communicate with CWS500N 1.2
- #8233: RadiMate slow measurement speed
- #8247: Tektronix Oscilloscope returns No data or incorrect data was returned by the device
- #8334: No measurement data during "Continuous Measurement" as altitude scan using CO3000 controller
- #8406: Password of a new engineer is unknown, and cannot be changed
- #8408: EUT Monitoring channel Maximum and Minimum Limits are not shown
- #8418: Maturo NCD over lan
- #8419: Settings in 'Fixed step count' frequency step setting in a multiband immunity test is not remembered
- #8420: Fixed step count as step frequency in multiband immunity is not working when 'per octave' is selected
- #8421: Agilent E4422B unable to connect
- #8422: Singleband GTEM emission data is not shown when a dot is used a decimal symbol
- #8423: HP 34401: Timeout while waiting for *OPC command
- #8430: Internal AM modulation on the Agilent E4422B is not supported
- #8433: Exporting of graph data to CSV is not always in Excel compatible format
- #8435: Allow control of CANoe 9.0.65 (SP2)
- #8436: Also notify the CANoe CAPL interface of dwelltime start and dwelltime end
- #8437: Possibility to leave CANoe running when the CANoe switch matrix is used
- #8441: Changing polarization of Frankonia FC02 raises 'Illegal parameter value' error
- #8455: Black lines in RI tests
- #8456: Conducted RF immunity stepsize 0,5 per cent not possible
- #8464: Changing region settings causes data loss.
- #8469: Agilent Technologies E4422B: "Undefined header" when turning off AM modulation
- #8475: When changing step frequency of 1 band, all the bands step sizes change.
- #8476: R&S ESI: Function not available: INP:GAIN:STAT OFF, when FFT filter is used
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2017.1.
