New version: RadiMation version 2017.1.6
Posted: 21 Dec 2017, 12:33
We have released an updated minor version of RadiMation software, which includes several new device drivers and some small fixes for problems that have been detected since the release of the 2017.1.5 version.
The new 2017.1.6 release of RadiMation can now be downloaded from the DARE!! web-site.
We are currently not aware of known issues in this version.
The following issues are fixed in this 2017.1.6 version (compared to the 2017.1.5 version):
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2017.1.
- #4969: CANoe interface object not initialized correctly
- #7829: Implement the AnalyserAsPowerMeterDecorator for ESU and ESI series powermeter device drivers
- #8062: Outside Points
- #8340: Ability of 'Power Measurement' settings for the R&S ESR7 to avoid unexpected bandwidth jump behavior
- #8378: Enabled Calibration before final measurements option causes GPIB: EABO timeout
- #8384: External reference setting of the R&S ZNB is changed during initialization
- #8412: Ability of 'Power Measurement' settings for the R&S ESU40
- #8450: ESPC Not all bytes are written to the GPIB board "Perform short calibration before final measurement" option
- #8467: RI Multiband AM modulation is only used for first point, after that its none if modulation conservation is activated
- #8477: RadiLog Error Report does not make screenshot from external monitor
- #8479: Maturo MCU raises a Lock error during deinitialization
- #8481: Driver: RSSA3021X Spectrum analyzer
- #8483: R&S ESIB40: Function not available;FREQ:STOP:LINK START
- #8488: N9038A: System Error: -410: Query Interrupted
- #8493: CARAD software invalid messages received
- #8503: Marked peaks are not saved
- #8504: Minimum power of CI Fixed power test is -40 dBm
- #8508: Ability to select Internal or External reference clock on some devices
- #8510: Changing unit causes crash
- #8511: Frequency correction of PMM EP603
- #8512: Device Driver: Marconi 2052
- #8518: Not possible to generate a printout of the amplifier linearity test results
- #8523: Compression test table: uses wrong unit in time and frequency column
- #8526: Generated power of CWS500N1 drops at 350 kHz
- #8527: RSSML Merge reference source
