New version: RadiMation version 2018.1.5
Posted: 25 Oct 2018, 10:08
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2018.1.4 version.
This version 2018.1.5 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2018.1.5 release of RadiMation can now be downloaded from the DARE!! web-site.
The following issues are fixed in this 2018.1.5 version (compared to the 2018.1.4 version):
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2018.1 .
- #5636: R&S ESPI 3 error Data out of range SCAN1:BAND:RES
- #8066: Extend the DSA832 pre-amp option detection
- #8113: Unable to communicate with CWS500N 1.2
- #8514: Driver: emtest Compact NX
- #8521: Detection if the Keysight GPIB card is used is not working anymore with Keysight IO Libraries Suite 2018
- #8715: Rigol DSA 832: Specific System Error: -220, "Parameter error"
- #9438: Not all data from PMM9010 is received due to RS232 buffer overrun
- #9379: Graphline does not display (RBW 10 Hz)
- #9423: Driver: R&S FPC1000
- #9455: Singleband frequency rounded
- #9457: Driver: Signal generator Aeroflex 2023
- #9463: No validation error is shown on the erroreport dialog in a new installation
- #9464: R&S SML signal generator should not use RSSML::msBuffer class member
- #9505: The red dashed 5.1 and 3.1 dB limit lines are not shown in the amplifier linearity test
- #9516: PMM9010: Incorrect start and-or stop frequency when 1 MHz RBW is used
- #9522: Amplifier Reflected power does not show 2018.1.4
- #9537: Backport logging in clsGraphDrawer.Update to 2018.1.5
- #9543: Could not load file or assembly 'MindFusion.Common.WinForms'
- #9565: Radifield 2018 Error 1 on init. Wrong command
