This version 2018.2.5 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2018.2.5 release of RadiMation can now be downloaded from the DARE!! web-site.
The following issues are fixed in this 2018.2.5 version (compared to the 2018.1.5 version):
- #8751: Renaming a test-level input in a multiband immunity test, removes the second, if they both have the same name.
- #9055: Remote operation of the RadiLink is not always indicating error situations
- #9324: ErrorReport: "Collection was modified; enumeration operation may not execute.
- #9335: VI Window crash at closing
- #9517: Keywords changed
- #9591: Object reference not set to an instance of an object: ctlControlStop.CancelCommands(
- #9604: Report Error does not handle polish characters
- #9670: Auto stepsize of TDEMI is set to 5 kHz, even if 120 kHz RBW is selected
- #9685: Attachments of the EUT File are corrupted
- #9693: Add printout templates for CI Callibration and C Susceptibility
- #9714: Deadlocking in clsDataIdentifiers.
- #9717: Change menu order for Pulsed Imunnity tests.
- #9742: Changing a sequence file does not work correctly.
- #8381: Impossible to remove graph line from different test data when the file has been closed
- #9572: Red dots as quasi peak markers
- #7975: Communication interrupt during EFT test
- #8041: Agilent 9038A as powermeter
- #8221: RadiMation logo in graph is not shown first time a test is opened
- #8280: Test equipment for EUT Calibration of Attenuation / Gain cannot be changed
- #9679: Cannot find turntable in the currently active testsite.
- #8263: Opening non existing file with RadiLog crash Gives exception
- #9002: Also show the latest DRIVERS.EXE version on the RadiWiki Main page
- #9115: Temp filenames in creating new files
- #9202: Adding input fieldprobe without enabling any probe in RI MB test, is causing object reference
- #9224: In ErrorReport an unknown label 'usr agr' is present
- #9246: Script for copying latest RadiMation release to Radi-Products Production folder
- #9300: How to show the points only that have the status 'fail'
- #9301: ErrorReport: "ETS-Lindgren EMField 7008-005 FWD power: Parameter too low"
- #9312: EMI reciver switch to spectrum analyzermode while initialisation for conducted emission testing
- #9323: SystemCrash: Source array was not long enough. Check srcIndex and length, and the array's lower bounds.
- #9333: ErrorReport: "Cannot find the device driver.
- #9334: ErrorReport: "Startfrequenz ist zu niedrig fuer das gewaehlte Geraet"
- #9340: Driver: Shaffner Broadband Horn Antenna 1-18 GHZ - BHA 9118
- #9358: Radimation crashes when device is in use by other software
- #9372: How to remote control LISN R&S ENV216 with the R&S ESW 26 via radimation
- #9373: Rohde & Schwarz SMR 20 (ID7340): Specific System Error: 110,"Output unleveled"
- #9389: How do we set-up for testing acording EN6100-3-2 and EN 61000-3-3
- #9390: The file extensions of the template and the output document do not match
- #5636: R&S ESPI 3 error Data out of range SCAN1:BAND:RES
- #6351: How to configure the Monitoring input channel setup for the used AD Converter device driver
- #6377: How to enable or customize the borders of the grid of the exported table information of the ||EQUIPMENT TABLE|| keyword
- #6380: Would it be better to do fewer sweeps with a long sweep time or many sweeps with short sweep time?
- #6392: How is the Monitoring input channel formula option used?
- #8760: The CheckDevice check for Amplifier Research amplifiers using the P0/P1 command set is always succesful
- #8795: Driver: switch matrix: MCC USB-ERB24
- #8797: Driver: Antenna tower controller HD GmbH IEEE488-16REL GPIB
- #9142: Driver: Mini-Circuits PWR-6GHS
- #9331: Radiated immunity RF on but not scanning
- #9547: Schloeder CWG500 is waiting forever on a discharge trigger
- #9551: Problem with ECU-6 Communication
- #9559: RF Amplifier (ID1344): Prana returned a warning state.
- #9575: Problems controlling the Keysight Technologies CXA (N9000B)
- #9590: Index was outside the bounds of the array. clsDataIdentifiers.Add
- #9610: Driver: Amplifier VBA250-80
- #9611: Driver: Clamp Schwarzbeck CVP 9222B
- #9612: Driver: CDN FCC-801-M2-16
- #9613: Driver: LISN - Rohde & Schwarz: ENY 41
- #9614: Driver: Pulse Limiter - Rohde & Schwarz ESH3-Z2
- #9615: Driver: LISN - Schwarzbeck CAT3 8158
- #9617: Driver: Calibration Adapter FCC-801-150-50
- #9647: Closing a device window crashes radimation - Exception has been thrown by the target of an invocation
- #9673: Collection was modified; enumeration operation may not execute.
- #9701: Driver: Keysight Technologies MXA N9020B + CXA N9000B
- #9709: Driver: Schaffner SCR 3501
- #9713: Communication time out RPR2006C
- #9761: ErrorReport: "RBW switched to Auto(100kHz) during 30M-1G test
- #9595: R&S ESI 40 GPIB randomly stops communication
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2018.2 .
