This version 2018.2.7 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2018.2.7 release of RadiMation can now be downloaded from the DARE!! web-site.
The following issues are fixed in this 2018.2.7 version (compared to the 2018.2.6 version):
- #5562: Adjust the calculation of the Bursts to be in compliance with the 1.8.2 version of EN 300 328
- #6732: Calculate TxSequence and TxGap times accoording to ETSI EN300328 V1.9.1
- #9298: Duty Cycle of Burst measurement is not correctly calculated
- #9689: Height graph in Multiband emission is showing up to 2.4 km.
- #9727: Driver: BONN BAS 0060-4
- #9752: Driver: Rohde & Schwarz signal generator SMB100B
- #9789: Antenna height does not scale properly.
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2018.2 .
