New version: RadiMation version 2019.1.10 (BETA)
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2019.1.9 version.
This version is released as a BETA version because it provides a fix for the following tickets:
  • #10537: SMB 100A: Specific System Error -222, Data Out of Range
  • #10616: Rohde & Schwarz SMB 100A: Specific System Error: -222,"Data out of range; :SOURce1:POWer:POWer 41.2388
This version 2019.1.10 is at this moment only provided as a BETA release, as it has NOT YET been fully validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2019.1.10 BETA release of RadiMation can now be downloaded from the DARE!! web-site. Image
  • This is a BETA release that has not yet been fully validated.
  • #9118: Ambient suppression in Multiband Emission GTEM causes that the GTEM correlation is not performed.
The following issues are fixed in this 2019.1.10 version (compared to the 2019.1.9 version):
  • #10112: Radimation crash when opening the advanced dialog of a horn-antenna driver for a second time.
  • #10357: Maturo NCD tower and turntable
  • #10366: Driver: Receiver/Analyser Tektronix RSA6114A
  • #10390: Driver: Tektronix TDS5054B AD Converter Driver
  • #10399: EM-TEST UCS500N7 - Surge test is not working
  • #10417: Eventlog is showing an additional column 'Setting ID' with: 'DARE.RadiMat.clsDataIdentifierSetting'
  • #10441: Polarity of test generator
  • #10422: DARE!! Instruments RPR2006C: Timeout expired before operation completed.
  • #10494: Driver: Pearson Model 101
  • #10524: Driver: DARE!! Instruments RGN2006A
  • #10531: MK Messtechnik - Initialization before AND After each test
  • #10541: Driver: DARE!! Instruments RGN2400A
  • #10570: RI Substitution Single Band - modulation: Pulse states"With Voltage conservation"
  • #10573: Driver: RadiGen 2400A changed commands.
  • #10576: Driver for monitor input for the NSG4070
  • #10578: EMTEST UCS500N7 - Surge test is not working when controlled remote
  • #10582: Rohde & Schwarz ESI 40 Input 2: Specific System Error: -222,"Data out of range; SCAN1:BAND:RES 1 KHZ
  • #10585: DARE!! Instruments RSW1021N: Wrong command Accepted use of data: True User
  • #10596: The enhanced status window is popping up during a band switch.
  • #10598: ||SELECT [Frequency (MHz)], [RBW: 9 kHz, Neutral Max Peak (dBµV)] FROM RBW: 9 kHz, Neutral Max Peak TABLE|| does not resolve.
  • #10606: Driver: Wavecontrol SMP2
  • #10608: Driver: R&S BBL200
  • #10611: CI- When starting test we get the error "Teseq NSG 4070 Driver function not implemented"
  • #10612: Driver: R&S USP220 switch matrix with module B107
  • #10626: Error at SMF100A command in our driver
  • #10627: PMM EP601 Not using selected filter settings
  • #10630: Keysight technologies N5172B: Specific system error: -410, "Query INTERRUPTED"
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2019.1 .
