New version: RadiMation version 2020.0.9
Posted: 24 Mar 2020, 15:00
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2019.2.5 version.
This version 2020.0.9 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2020.0.9 release of RadiMation can now be downloaded from the DARE!! web-site.
We also include several improvements and new functionalities in version 2020.0.9, the most important improvements are:
The following issues are fixed in this 2020.0.9 version (compared to the 2019.2.5 version):
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2020.0 .
- General code improvements
- In total 65 improvements or fixes
- #10495: Driver: R&S FPL1000.
- #10493: Driver: Tektronix MDO 3014
- #10492: Driver: TESEQ MD4070.
- #8916: Agilent 33250 as external modulator
- #10365: Driver: TurnTable XYZ.
- #10426: Radimation calibration does not scale properly anymore.
- #10461: Change device driver names for Dare!! CDN's
- #10476: External 20 dB Attenuation: RS232: Setting the Baudrate attribute raised an error.
- #10484: N9038A: Not able to select more then one trace.
- #10485: Driver: Schwartzbeck CDN M2.
- #10486: Driver: Schwartzbeck CDN M3.
- #10487: Driver: Luthi CDN AF2.
- #10488: TESEQ T2-10.
- #10489: Driver: TESEQ A201A.
- #10490: Driver: Schloeder CDN M2-32A.
- #10501: LUMILOOP LS Probe 1.2: Device Not Connected.
- #10508: Possibility to remove the RadiMation logo from the emission graphs in the report?
- #10526: Driver: Schwarzbeck UBAA 9114
- #10538: Die Sammlung wurde geändert. Der Enumerationsvorgang kann möglicherweise nicht ausgeführt werden.
- #10592: The default port of the RadiCentre LAN is wrong.
- #10595: During rotation of turntable, the tabs on the Multiband test become disabled.
- #10602: Driver: AR JB6.
- #10603: Driver: AR 30S1G6.
- #10607: Driver: Horn Antenna ATH800M6G.
- #10610: R&S ESRP 3: 1st 2 peaks measured is with correct 120 RBW, 3th & 4th are measured with 100 kHz RBW
- #10623: Driver: MultiMeter Keysight 34450A.
- #10628: BBL200 idn check returns Rohde & Schwarz,BBA150.
- #10629: BBL200 Timeouts.
- #10666: Description for this error is not available. Error nr.: 536881313
- #10669: DARE!! Instruments RGN6000B HF (USB): Frequency tried to set is lower than the start frequency (9000 Hz) or higher than the end frequency (6000000000 Hz) of the device driver.
- #3522: Agilent 8753ES is giving EABO error first time RadiMation starts
- #10521: Checking the driver for R&S NRX indicates that the device is not connected
- #10639: Driver: COM-Power CDN-T8SE (LISN).
- #10640: Driver: Schwarzbeck CAT5 8158 (LISN).
- #10641: Driver: COM-Power ISN T8.
- #10644: Driver: Rohde & Schwarz MDS 22.
- #10645: Driver: Minicircuits TIA-1000-1R8
- #10674: GAUSS TDEMI X - When using a step size of 100kHz the results do not match the results on the analyser
- #10687: Cannot find antenna tower in the currently active testsite.
- #10751: R&S ESW8 Pulse limiter on RF input 2.
- #10763: Formulas in the manual are not displayed correctly
- #10766: D.A.R.E!! Instruments RGN6000A: Setting the frequency raised an error
- #10786: Send Data To RGN2001A switch matrix ATT2 (9KHz-800MHz): Impossible to get description string for this Error! Probably an unknown RadiMation Error
- #10801: mk Messtechnick OSD driver of 2020.1.27.1708 is not sending any comments
- #10802: mk Messtechnick OSD shows random "black spots"
- #10803: Clearing a longer text from the mk Messtechnick OSD leaves the background color set
- #10804: modulation type is transmitted continuously to the mk Messtechnick OSD
- #10806: MK Messtechnick OSD is not cleared correctly
- #10808: Time and Date are always displayed on the mk Messtechnick OSD, even if the checkboxes are unchecked
- #10809: mk-Messtechnik on screen text display driver does not work
- #10816: Only rounded steps are possible when using a logarithmic step size.
- #10821: R&S ESI Powermeter can be improved when very small frequency steps are used
- #10826: Driver: Prana 25 S
- #10646: Driver: Schwarzbeck CDN 801.
- #10647: ErrorReport: "DARE!! Instruments RGN2400A: The requested carrier level is higher than the maximum ( 13 dBm). Limited the set carrier level to 13 dBm. "
- #10769: R&S FPL 1007 - The set value of attenuator is not set in the spectrum analyser. During measurements value is set to 0 dB.
- #10807: Time and Date on the mk Messtechnick OSD are only displayed on output 2
- #10817: Radiated Emission manual mode uses the default unit for field which is defenided at radiated immunity
- #10829: Rohde & Schwarz NRP6AN (1-0944): Specific System Error: -148,"Character data not allowed; SENS1:FREQ 540000000 HZ
- #10831: Radiated Immunity MB with frequency list file shows incorrect power with hz steps.
- #10391: Driver: Schwarzbeck NFCN 9734 Switch Matrix Driver.
- #10618: ||TIME; FREQUENCY;.TABLE 30 s|| works in 2017.2.7 not in 2019.1.9
- #10822: Radiated Immunity test doesn't show 1hz steps.
- #10833: Multiband Immunity graph does not look correct
