This version 2020.0.10 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2020.0.10 release of RadiMation can now be downloaded from the DARE!! web-site.
We also include several improvements and new functionalities in version 2020.0.10, the most important improvements are:
- General code improvements
- In total 5 improvements or fixes
The following issues are fixed in this 2020.0.10 version (compared to the 2019.2.5 version):
- #10605: Frequencies of injection and calibration jig are not remembered
- #10659: BONN BLMA 1060-75-50: Add monitor command to the driver
- #10846: Driver: Electro metrics 6913.
- #10855: TDEM-X26 gets frozen after update driver package
- #10866: Die arithmetische Operation hat einen ??berlauf verursacht.
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2020.0 .
