New version: RadiMation version 2020.0.11
Posted: 30 Apr 2020, 16:11
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2019.2.5 version.
This version 2020.0.11 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2020.0.11 release of RadiMation can now be downloaded from the DARE!! web-site.
We also include several improvements and new functionalities in version 2020.0.11, the most important improvements are:
The following issues are fixed in this 2020.0.11 version (compared to the 2019.2.5 version):
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2020.0 .
- General code improvements
- In total 22 improvements or fixes
- #10106: CISPR detectors are not selected or not selected correctly - ESU 8 - ESW26.
- #10659: BONN BLMA 1060-75-50: Add monitor command to the driver
- #10782: Pause Test alwas asks to save after closing it or when the counter is finished.
- #10812: Driver: Frankonia CDNE M2 / M3.
- #10827: Driver: Van veen loop.
- #10838: Polarizer battery empty errors are shown at inconvenient moments
- #10855: TDEM-X26 gets frozen after update driver package
- #10871: Issue 2020-03-26_AL2_mk Messtechnik OSD shows no output
- #10872: Error in RadiLog: Template (VARIABLEREPLACER.OBJ) Copied to:.
- #10874: TDEMI_X26: Specific System Error: -114,"Header Suffix Out of Range; SENS:SCAN4:STEP?
- #10875: TDEMI_X26: No match was found in the specified regular expression.
- #10878: Bonn amplifier is going into a loop
- #10884: Rohde & Schwarz ESW 8 Input 2 Time Domain: Specific System Error: -222,"Data out of range;SCAN1:STOP 1100000000 HZ"\n) using ESW8 Input2.
- #10885: Driver: add Rohde & Schwarz ESW Input 2 driver for powermeter.
- #10886: Driver: add Rohde & Schwarz ESR Input 2 driver for powermeter.
- #10887: Spectrum Analyser (ID1556) Input 2 (LAN): Impossible to get description string for this Error! Probably an unknown RadiMation Error. Code: 1073741975 (0x40000097)
- #10889: RI - Not possible to measure on points
- #10899: Ni cDAQ analog value max +-15 Vdc
- #10901: Temporarily disable the automatic calculation during the generation of an excel report.
- #10919: GTEM-1_SMB-100A: Impossible to get description string for this Error! Probably an unknown RadiMation Error. Code: 805317371 (0x30002AFB)
- #10929: Rohde & Schwarz ESPI 3 Scanning Receiver (QTR:15): Specific System Error: -200,"Execution error; Function not available; BAND:TYPE NORM
- #10934: R&S ESR 7:Make sure that CISPR average is used in the pre-measurement when "Use CISPR detector is applicable".
