This version 2020.0.12 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2020.0.12 release of RadiMation can now be downloaded from the DARE!! web-site.
The following issues are fixed in this 2020.0.12 version (compared to the 2020.0.11 version):
- #10768: Driver for PMM 9010/60P
- #10895: Issue 2020-04-01AL1_ra emission peak values dropped down in Diagramm
- #10909: Issue 2020-04-09 AL2_ OSD does not show current values of dwelltime in manual mode
- #10926: Change defaults in the stepper.
- #10927: Change default test level for the Calibrated Field Testlevel to V/m.
- #10928: Change default for modulation when you click activate modulation.
- #10933: The reportgenerator keeps searching for keywords in infinite loop when exporting the template directly after test
- #10966: Inn-Co CO 2000 (Unit 1): Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO).
- #10971: Issue 2020-04-09 AL2_ OSD does not show current values of calculated field in manual mode.
- #10976: Connection time-out when trying to connect to AR FA 7006
- #10979: Radiated immunity: Modulation and change mode are not displayed correctly.
- #10983: Driver: DARE!! Instruments RPR3006R
- #10989: R&S ESW8 Input 2, pulse limiter activation requires that DC Coupling is selected.
- #10990: Adjust Network Analyser Report Codes VSWR and ReturnLoss.
- #11005: Double click EUT file does not open in RadiMation.
- #11007: Dot and Comma issue when exporting data.
- #11010: Radimation Version 2020.0.011 Radiated Emission Manual - Antenna Factor.
- #11016: Agilent 8753: Specific System Error: 9, "CAUTION: LIST TABLE EMPTY".
- #11018: Antenna tower of Inn-CO CO3000 is not moving when controlled by Ethernet
The complete list of release notes can be found on: https://wiki.dare.nl/wiki/index.php/Rel ... tes_2020.0 .
