New version: RadiMation version 2020.1.9
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2020.1.8 version.
This version 2020.1.9 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2020.1.9 release of RadiMation can now be downloaded from the Raditeq web-site. Image
The list of available device drivers is continuously updated on the RadiWiki website. Also the end-user manual and error explanations are updated to clarify user questions.
  • Several new device drivers, some of which are:
    • Keysight Technologies N9048B
    • Keysight DSOX4014T
  • In total more than 12 improvements or fixes
The following issues are fixed in this 2020.1.9 version (compared to the 2020.1.8 version):
  • #10653: LAN Controlled INN-CO CO3000: Always error during deinitialization.
  • #10688: Teseq NSG 4070-35: RS232: The rs232 runtime data is not created.
  • #10879: No error is raised when the RadiGen is controlled while the interlock is not closed.
  • #10905: 1GHz: Attenuation set too high.
  • #10996: Error message from the Inn-CO CO3000 during deinitialization of the test.
  • #11161: Transient3000: How to setup the dip angle.
  • #11162: Transient3000: How to setup the reduced voltage time.
  • #11184: "DARE!! Instruments RGN6000B: Device returned Error code : 4005".
  • #11186: Exported average values are wrong.
  • #11187: Values are exported in linear scale but are expected as dB values.
  • #11259: Driver: Keysight Technologies DSOX3014T.
  • #11272: Driver: Keysight Technologies N9048B.
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2020.1 .
