This version 2020.2.9 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2020.2.9 release of RadiMation can now be downloaded from the Raditeq web-site.
The following issues are fixed in this 2020.2.9 version (compared to the 2020.2.8 version):
- #5282: Strange message for HP 8903A + 8903B (Motorola).
- #10091: Wrong start frequency/StartFrequency changed
- #11483: ErrorReport: "RBW fouten tijdens na meten pieken!!!!"
- #11605: Configurable LISN with manual messages, shows the messages too often
- #11606: Reference level of the Tektronix RSA507A is not correctly set at the begin of the test
- #11607: Attenuator of the Tektronix RSA507A is not correctly set at the begin of the test
- #11608: Change in reference level adjusts the top of the graph in Tektronix SignalVU, reference level itself is not changed
- #11609: Progress calculation of trace retrieval from Tektronix SignalVU stays on 0%
- #11611: R&S ESRP measures first average detector final measurement with different RBW
- #11613: Rigol RSA5065A retrieves trace before sweep is finished
- #11615: ErrorReport: "Wrong data in Peak Table at QP measurement"
- #11616: Boonton 9241 in 4230 emulation mode cannot be controlled by Boonton 4230 driver
- #11620: ErrorReport: "MK Messtechnik Motion detection"
- #11623: AMETEK CTS: Issue 2021-03-01_Angle and Height in Peaktable wrong
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2020.2 .
