This version 2020.2.10 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2020.2.10 release of RadiMation can now be downloaded from the Raditeq web-site.
The following issues are fixed in this 2020.2.10 version (compared to the 2020.2.9 version):
- #11479: Are Limit lines auto-included when exporting graphs using the report generator
- #11500: Driver: LadyBug LB480A
- #11633: Driver: Raditeq RPR3008W.
- #11640: Adjust raditeq IDN queries for raditeq devices
- #11653: Error 10 while controlling the old model of the EM-Test CWS 500
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2020.2 .
