New Version: RadiMation version 2021.2.7
Posted: 15 Nov 2021, 15:46
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2021.2.3 version.
This version 2021.2.7 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2021.2.7 release of RadiMation can now be downloaded from the Raditeq web-site.
The following features are added to RadiMation 2021.2
The following issues are fixed in this 2021.2.7 version (compared to the 2021.2.3 version):
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2021.2 .
- #2273: Multiband Conducted emission absorbing clamp.
- #5579: Stopping a sequence is almost impossible.
- #11795: Add ability to measure electrical fields of ~ +1000 V/m using a RadiSense
- #11806: RIGOL device driver is measuring too high AVG and QP detector values
- #11846: Measured differences between RadiMation and PMM software when Testing CE/RE
- #11962: Distance unit text is missing in generated reports
- #11965: ErrorReport: "Antenna distance incorrect after upgrade to new version (2021-1-6 -> 2021-2-3)"
- #11988: ErrorReport: "Unable to see cable under test descripton"
- #12040: Slow start of RadiMation Pulsed Immunity test
- #12050: ErrorReport: "Cannot find positioner"
- #12064: ErrorReport: fault "System._ComObject"
- #12078: Absorbing clamp Maturo FCU: Function not implemented error
- #12084: Correction file with Frequency unit in kHz only shows half of the graph
- #12087: Opening test data older than 2021.2.1 results in missing distance data
- #12088: ErrorReport: "RI with rot pos, 1 step, 120 degrees".
