New version: RadiMation version 2022.3.5
Posted: 31 Jan 2023, 16:31
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2022.3.4 version.
This version 2022.3.5 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2022.3.5 release of RadiMation can now be downloaded from the Raditeq website.
The following features/drivers are added to RadiMation 2022.3.5
The following issues are fixed in this 2022.3.5 version (compared to the 2022.3.4 version):
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2022.3 .
- #13345: Driver: Keysight U2021XA
- #13348: Driver: ETS 7002-008.
- #11073: Wrong display of "Field 11 V/m AM" for Horizontal RI Test
- #11642: Calibration file of horizontal is also used for vertical polarization of the second band
- #11895: Calculated field calibration file of the first band is used in the calculations of the other configured bands
- #12480: RI multiband measurements (V+H) - Deviation in calculated test level
- #13258: Configuring a multiband test with multiple bands testing on different polarisations result in incorrect measurement results
- #13308: Relay Unit SC1000 not switching
- #13330: Communication error with LSProbe 2.0
- #13335: Report generator does not replace expected keywords compared to previous versions.
- #13338: The axis of the Lumiloop LSProbe 2.0 are reported in a different order
- #13342: HI 6153 raises error 3
- #13344: Raditeq driver shows ETS identifier in settings.
- #13359: Error no average probe is selected
- #13361: Word report: correctly handle text in bullits and headers
- #13363: Report generator does not insert data of a valid keyword when table data is inserted into another table
