New version: RadiMation version 2022.3.8
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2022.3.6 version.
This version 2022.3.8 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2022.3.8 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2022.3.8 version (compared to the 2022.3.6 version):
  • #13201: Device driver: Keithley 2700
  • #13242: Teseq PMU 6006 gets error during testing
  • #13486: Communication issues with rotational probe positioner
  • #13514: Antenna tower is moved when the amplifier linearity test is started
  • #13518: Field Sensor measurement result was 0 V/m.
  • #13533: FPC Fix incorrect measurements when measuring parallel detectors during the final measurements
  • #13537: Radimation data storage error during test
  • #13566: RadiSense 10 returns 0.0 V/m on all axis
  • #13568: Which RBW is really active during the sweeps
  • #13569: SAC10 - Radimation 2022.2.3 Error message at startup "Acces to the path 'C:\TSFDIR.INI' is denied."
  • #13573: TDEMI G supports multiple input ports
  • #13622: Object reference error when closing emission test
  • #5616: Changing RGN output is not correctly updating frequency range
  • #9965: Closing Powersensor mini-circuits PWR-SEN-6GHS panel from 'Devices' crashes Radimation
  • #10330: Controlling the Mini-circuits PWR-SEN-6GHS from different threads causes crashes
  • #13270: Driver: Specialized device driver for the Fluke 8845A
  • #13307: Driver: Extending the RadiPower 4000 series driver to 4 kHz with additional filters
  • #13340: Mini-circuits power meter PWR-SEN-6LRMS does not work
  • #13387: Printing a test result, results in a word error, file not found.
  • #13391: Changing the polarization of the Frankonia FC06.1 results in an error -101
  • #13395: Implement blocking print call
  • #13417: Configuring the Customer Database returns "This is not a valid Device Driver"
  • #13423: Error after disabling graph lines in an immunity graph
  • #13424: ESRP keeps max hold on screen on the device while frequency was changed
  • #13430: Data lost from perfomed tests (Conducted emissions) in February
  • #13431: Improve *IDN? check of RadiField 1000-series
  • #13438: No error description available when device not found
  • #13440: Cannot find devices using Auto detection
  • #13442: Rhode&Schwarz BBA100 Interlock
  • #13445: Wrong current measurement with 34465A multimeter
  • #13452: Rigol RSA3030E-TG firmware not supported.
  • #13453: Label impedance has caption: Caption, in S22 result.
  • #13454: R&S FPC1500 Average measurement does not work.
  • #13465: Span error in GTEM Single band test with Rigol DSA832
  • #13466: EMPower 7002-008 reports it can be used from 9 kHz
  • #13468: Keysight IO Suite reports that a VXI-11 communication is a TCPIP stream, causing errors when setting VI_ATTR_TCPIP_KEEPALIVE
  • #13469: The file property information of VISA32.DLL should be logged in RadiLog
  • #13471: graph scaling persistable error on start up of RadiMation
  • #13476: R&S FPC1500 Decvice check fails on drivers 2023.03.08.1406
  • #13479: R&S FPC1500 Take sweeps after final measurement is done on wrong frequency span on analyzer
  • #13480: Error when disabling all graphs
  • #13488: Timeout errors GPIB: EABO
  • #13490: Overshoot of polarisation change of the Frankonia FC06.1 is not corrected
  • #13494: Changing note content created at a different moment will result in saving an additional newline character
  • #13495: Correctly load the user correction into the RadiSense 10 probe
  • #13496: SMB100B driver accepts 4 kHz FM DEV, but warning messages are presented on the screen of the device.
  • #13530: RadiSense 4 returns 0.0 V/m on all axis
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2022.3 .
