New version: RadiMation version 2023.1.7
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2023.1.6 version.
This version 2023.1.7 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2023.1.7 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2023.1.7 version (compared to the 2023.1.6 version):
  • #13837: Agilent 33521A: "Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO)"
  • #13833: Confirming a new to angle in the VI instrument windows by pressing enter does not result in movement
  • #13831: about external square wave modulation
  • #13827: GPIB delays
  • #13825: Update DevExpress to 22.1.10
  • #13824: Cannot connect to Frankonia VLH amplifier
  • #13817: Auto filter is not available in the RadiPower RPR4000 series
  • #13812: Driver: Frankonia VLH coupler
  • #13804: Driver: ETS-Lindgren 7002-009
  • #13801: Driver: R&S OSP320 switchmatrix
  • #13800: Driver: Frankonia VLH-700B1
  • #13795: R&S ESR seems to hang when it starts a new scan in the 1GHz - 3GHz range but not in the 30MHz - 1GHz range
  • #13794: Cosmetic issues regarding the alignment labels in RI Multiband
  • #13792: Select another band after removing a band in a multiband test
  • #13789: BB graph - setting of marker does not work
  • #13767: Driver: Lecroy HDO 6034-MS
  • #13766: Driver: Keysight MSOS054A
  • #13765: Driver: Lecroy WaveRunner 8038HD
  • #13718: Different RBW values cannot be configured as expected because of auto completion of the value
  • #13678: TDEMI U6 - Radiated Emission - measurement results contain noise not seen on the device.
  • #13654: EUT information items should not allow items starting or ending with new line characters
  • #13653: Saving the content of the note adds an additional newline character
  • #13608: Editing in Note Tab not possible, only via "Note" button
  • #13599: AD-Converter Keithley (Scanner) shows error -133 undefined header on the display
  • #13565: Readout of the TDEMI Gauss Ultra 6 seems to repeat the measured data
  • #13556: Driver: FPP 2,3/1.5 support for the Maturo FCU3.0 and NCD controller
  • #13426: TDEMI repeats measurement on frequency step for several times
  • #11939: Differences in the behavior of the shown test events between Singleband and Multiband
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2023.1 .
