New version: RadiMation version 2024.1.6
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2024.1.5 version.
This version 2024.1.6 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2024.1.6 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2024.1.6 version (compared to the 2024.1.5 version):
  • #13074: Improve resolution calculation for the AFJ FFT3110 receiver
  • #14151: Improve multiple dongle management in RadiMation
  • #14258: Audivo Pecos 7.1 support
  • #14459: Add pulsed immunity sequence overview keyword to export sequence configuration to a table
  • #14695: Driver: Audivo Pecos 7.1
  • #14750: Improve detection of RadiMation license keys
  • #14868: Calibration file name creator now also has a test level description option
  • #14490: A report generator keyword which can output a test overview of an EUT in table format
  • #15058: CI calibrations use the same report functionality as the RI calibration document
  • #15063: Attenuation system test can now generate reports after the test is already performed
  • #15065: correctionfile copy-paste unit tests should not use the actual clipboard
  • #15085: Add pulsed immunity sequence overview report generator keyword
  • #15123: Update of RadiField firmware prevents bricking of the plugin card
  • #15132: License key is sometimes detected as Essential even though it is a Pro license
  • #15133: Software protection key error without valid license
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2024.1.
