Can I make a selection from the attachments?
Is it possible that I can make a selection from the attachments of a test? It is necessary that they are placed on different locations in the report with use of the Report Generator.
Re: Can I make a selection from the attachments?
It is indeed possible to select a specific attachment for your Report. Normally this is done with use of the following keywords;
||Attachment 1 Contents||
||Attachment 2 Contents||
Where "ATTACHMENT 1" is the number of the attachment. The Report Generator will then insert all the attachments of 1 on the keyword location at once.
However it is also possible to include a photo or any other file that is attached to an external test results test into the report.
The report generator code that should be used:
||ATTACHMENT PHOTO.JPG CONTENTS||
Where "PHOTO.JPG" is the name of the attachment. It will select the specific attachment for insertion.
Additionally, this information is explained in the manual: http://data.dare.nl/wiki/index.php/Micr ... tor_editor under 'Inclusion of other files'.
Somehow I don't manage to get a picture imported from attachments into the report through the report generator.
I added a picture called ce_lisn.jpg in attachments. In the report I added the keywords ||InsertFile(<ATTACHMENT ce_lisn.JPG CONTENTS>)||. Firstly, I get the remark "Found New Code..." with the request which test I want to use for the keyword "" that is available in the template. As this doesn't consider a test specific template in my opinion, this is an unjustified remark. Continuing by skipping this or selecting a test doesn't however insert the desired picture.
Other variations I tried (also to import directly from harddisk):
|| ATTACHMENT ce_lisn.JPG||
||ATTACHMENT ce_lisn.JPG CONTENTS||
||InsertFile(<ce_lisn.JPG>)||
||InsertFile(ce_lisn.JPG)||
||InsertFile(<fullpathtopicture\ce_lisn.JPG>)||
||InsertFile(<fullpathtopicture\ce_lisn.JPG CONTENTS>)||
||InsertFile(<ATTACHMENT fullpathtopicture\ce_lisn.JPG CONTENTS>)||
||InsertFile(ATTACHMENT ce_lisn.JPG CONTENTS)||
||InsertFile(<ATTACHMENT ce_lisn.JPG>)|
none of which seemed to do the trick.
Filip
Filip
Attachments that are attached to the EUT document can be exported by the code:
||EUT|ATTACHMENT ce_lisn.JPG CONTENTS||
In RadiMation 2017.1.6 I have also tested the following code:
This report generator code also seem to work for EUT attachments. Yet this does unnecessarily asks to select a test.
The RadiMation manual is also updated
http://data.dare.nl/wiki/index.php/Chap ... ther_files
