Beginners guide for RadiLog and Automatic Error Reporting
The latest versions of RadiMation has a build in logger. Normally we prefer to use this dedicated logger to provide us with information.
Beginners guide for full Automatic Error Reporting (after an error):
A0. During the test or check an error is raised and the RadiMation Error Window is shown.
A1. At the RadiMation Error Window, click at the button "Details". Now the window is extended, and press the "Report" button.
A2. Once pressed on the "Report" button, the Error Report window will popup.
A3. Please fill in the additional information like requested. This information is also used to contact you about the reported problem, thus please ensure the correctness.
A4. The report can now be send to the Support department. Just hit the "Send button"'.
A5. The complete report including communication logging has now been send to our Support department.
Beginners guide for manually Automatic Error Reporting (no error is shown):
B0. Shutdown all RadiMation and/or RadiLog windows. (Re-)launch RadiMation.
B1. Start the test, which you experience issues with.
B2. Complete the test.
B3. At the RadiMation main menu click the item "Help" and press the "Report Error" item.
B4. Once pressed on the "Report Error" button, the Error Report window will popup.
B5. Please fill in the additional information like requested. This information is also used to contact you about the reported problem, thus please ensure the correctness.
B6. The report can now be send to the Support department. Just hit the "Send button"'.
B7. The complete report including communication logging has now been send to our Support department.
Beginners guide for RadiLog Reporting only:
C0. Shutdown all RadiMation and/or RadiLog windows. (Re-)launch RadiMation.
C1. Open the RadiMation RadiLog (logging tool) from the RadiMation main menu item View->RadiLog.
C2. Leave the RadiLog window open from now on, also during the test (or until the problem/crash happens).
C3. When the problem has past or occurred, select the RadiLog window.
C4. Select from the menu of RadiLog File->Save As... to save the debug and communication log to disk.
C5. Send an e-mail to support@radimation.com and attach the log file from previous step. Always include an extensive problem description as well!
For more detailed information, including screenshots also see our wiki page for the RadiLog and error reporting:http://wiki.dare.nl/wiki/index.php/RadiLog
Beginners guide for NI I/O Trace / NI Spy:
In case you have been specifically requested by the Support team to create a I/O trace logging file, see this post for a detailed explanation: viewtopic.php?f=3&t=126
