Synchro of test sites between different user PC's
Sofar i understand in Radimation has each local PC (PC1) his own "Test sites" configuration (defined in the "ConfDvdr" directory) and is it not possible to synchronise these test sites to an another PC2.
The only way to have a copy of this ConfDvdr of PC1 in PC2 is to delete the old one and paste the new one. We want the possibility that both PC's can make new testsites and share it with each other.
Is there no another simple way to synchronise these two PC's. As example copy of the complete "ConfDvdr" of PC1 to an external server and copy action from external server to PC2. Is this allowed.
Mueller
Re: Synchro of test sites between different user PC's
Post by Mueller »
Just use a Network installation. See chapter 2.2.2.2 in the manual. With the Network Installation all computer use the same configuration and share the same EUT data. In our configuration we have 3 test places. Each site has a Radimation installation and uses the Network ConfDvdr. When we move to a other site and start testing the data is collected in the same EUT file.
As a site effect, you may open a test on different computers at the same time even just this same test is running somewere else. The other PC displays a copy of the test till the moment it was saved last.
We collect the test data for our test reports using an office PC that has a Radimation installation but without a donkle.
Hoever, make sure all computers use the same Version of Radimation! A test stored or updated from a 2017 Radimation cannot be opened using a 2016 Version.
ruchikad
Post by ruchikad »
Excellent answer by Mueller. Really very informative post. Thank you!
