Limit line/Reference line units
Where can we change the unit of the quantity Frequency. Standard it is defined in kHz. we want to change it to Hz.
Re: Limit line/Reference line units
You need to change the unit to Hz before you start the calibration. On the right hand side in the calibration set-up screen there is a button called "unit" If you click this you can set the unit for frequency. However I tried to set this and I saw that the unit remains to be displayed in Mhz. I've made a ticket to fix this bug and will let you know when this is fixed.
