Is LLF data saved independently with TSF
Posted: 18 Dec 2012, 15:42
I have another question. If any Limit Line File (LLF) is saved into a Test File (TSF) is it then also saved inside this TSF? So, if I now want to move or replace the LLF itself, does the measurements (test data) and the TSF files which where using that specific LLF still be untouched?
Re: Is LLF data saved independently with TSF
Posted: 18 Dec 2012, 15:57
It is correct that the LLF data is saved inside the TSF itself beside the fact that it is saved with any test result data. The contents of a selected Limit Line is therefore copied into the TSF file when the Limit line file is selected.
So, in the screenshot the data of the added LLF (Example LLF) is saved inside this TSF. The original LLF can even be deleted and still the TSF will not get corrupted or lose any data.
- Example LLF
- Example LLF.PNG (68.64 KiB) Viewed 4821 times
