Difference between "conservation on power or voltage"
Posted: 21 Jun 2017, 15:27
What is the difference between "conservation on power" or "conservation on voltage" during modulation. There is now a little confusion at NLR how the two functions work and when to use power conservation or voltage conservation. Normally at MIL-STD-461 and ED-14 the generator level at 100% AM SW is 6 dB lower then at CW (100% AM SW should have same level as at CW). It looks that in the past this was accomplished by using power conservation. Now it looks like that this is accomplished by voltage conservation. Using now Radimation 2016.2.8. Has something changed during the software releases?
Ps: for power conservation the level only drops by 2-3 dB.
Is it depended on the way of controlling: Pin or Pfwd or (Pfwd - Prev)?
