Strange unit of quantity E-field
For the quantity E-field the unit dBµV has changed to dBŵV. First we have looked to the keyboard, region and language settings of Windows 10. They looked oke. It only appears on one laptop for already a few days. The other laptop is oke. We have re-installed Radimation version 2016.2.10 again, but the problem still appears. Also on Radimation version 2016.2.8 and 2017.1.1 this problem occurs, however only for one laptop again. We still are a little bit confused if this is a Radimation configuration setting or a Windows 10 problem.
Also the unit dBµA has changed to dBŵA and °C has changed to Å°C.
Re: Strange unit of quantity E-field
We indeed can confirm that in some device driver versions this problem is present.
We also did found out this problem.
Updating to the latest device drivers should fix the problem.
Have updated the latest device drivers. Re-started the computer. The problem still assists.
We checked it again, and we found that the latest drivers as they have been available for download did contain a small part of an older software version, which triggers that this problem is still present.
We now fixed this, and we updated the latest drivers. It now contains the correct patch.
We also double checked this, by downloading it ourself, and verifying if this indeed fixes the problem.
The latest downloadable drivers now do include the correct fix.
Please re-download and install the latest drivers again.
