how can I change the unit from the reference level? Actually there is dBµV selected, but I want to have dBm.
I have no correction files (with dbµV) in the test equipment selected.
thanks in advance
Steffen
Change the Unit from the reference level
Re: Change the Unit from the reference level
hi,
I do have some additional questions to give you a better answer:
- what type of measurement do you want to perform?
- what is the measurement setup that you are using?
- are you using multiband radiated emission?
Thanks in advance,
Sent from my HTC Vision Using ForumTouch for Android
Thanks in advance,
- I want to measure a WLAN signal.
- I have a wlan antenna connected to a signal generator(RF output: 2,4Ghz, 10dBm)
- Yes I'm using the multiband mode
thank you!
thank you!
hi steffen,
In the multiband tsf it is best to select 'antenna port and harmonics' as the 'location type'. A better name for the 'location type' is 'measurement type', which explains better the purpose of the setting.
When you select 'antenna port' the final measurement result will be expressed in power units. the desired power unit (like: 'dBm') can be selected by selecting the correct 'power' unit.
I hope that this solves your question.
Thanks a lot!!
You're right, maybe "location type" is not the best name for this option
Thanks a lot!!
