Hi at all,
after many years i want to use the radimation for measure disturbance power. TSF and setting are okay but there is something wrong implemented in the clamp movement settings. My problem is that i don´t have the option to adjust the the stepsize in accordance with CISPR 16-2-2 (table 3 and 4) . The software done only lineare steps depending on numbers of steps over the whole distance, that is wrong. Can you fix this soon. Maybe if this test would be multiband i can fix it myself but i dont have the option or dont find it.
Disturbance clamp setup not conform
Re: Disturbance clamp setup not conform
I can give you a heads up that we are currently working on the multiband absorbing clamp functionality
Using this functionality it will be possible to configure the clamp movement measurements to your requirements.
This functionality shall become available in a t.b.d future RadiMation release.
