If I create a new EUT in Radimation, I can define a lot of details like "date of measurement", "size", "HW release",... When I create a new row for example "voltage range", is there a keyword which I can use in the report generator?
thanks in advance!
						Keyword for EUT data
Re: Keyword for EUT data
Yes, there is indeed a keyword that you can use to retrieve the information from the EUT file into the report.
Just use the name that you used as the keyword.
Just to follow up on your example:
It is that easy!
Then the keyword for the report will be: ||EUT|voltage range||.When I create a new row for example "voltage range"
It is that easy!
good morning Joro,
oh, that's too easy
many thanks!!
						oh, that's too easy
many thanks!!
Is there also a way to permanently add a keyword, so it is there for every new EUT that is created?
Regards,
Filip
Regards,
Filip
Yes, it is possible to change the default EUT information data.
Please see the following page on our RadiWik site that explains this:
http://wiki.dare.nl/wiki/index.php/EUT_Information
Thank you for the quick and clear reply!
Filip
Filip
