Keyword for EUT data
tha-paul
Post by tha-paul »
If I create a new EUT in Radimation, I can define a lot of details like "date of measurement", "size", "HW release",... When I create a new row for example "voltage range", is there a keyword which I can use in the report generator?
thanks in advance!
Re: Keyword for EUT data
Yes, there is indeed a keyword that you can use to retrieve the information from the EUT file into the report.
Just use the name that you used as the keyword.
Just to follow up on your example:
Then the keyword for the report will be: ||EUT|voltage range||.
It is that easy!
tha-paul
Post by tha-paul »
good morning Joro,
oh, that's too easy :-)
many thanks!!
fvanhee
Post by fvanhee »
Is there also a way to permanently add a keyword, so it is there for every new EUT that is created?
Regards,
Filip
Yes, it is possible to change the default EUT information data.
Please see the following page on our RadiWik site that explains this:
http://wiki.dare.nl/wiki/index.php/EUT_Information
fvanhee
Post by fvanhee »
Thank you for the quick and clear reply!
Filip
