Would there be any way to customize the emission (or any other automatically generated) table? With all default parameters and colums it is almost impossible to get it fitting in a standard A4 report template without shrinking the text to nearly unreadable size.
best regards,
Filip
Customized emission table
Re: Customized emission table
Yes, there is a manner to modify the exported table.
This is documented in Chapter 13 (Report Generator) with the applicable keywords for the table: http://wiki.dare.nl/wiki/index.php/Chap ... sion_Table
It needs to be used in combination with SQL queries on the table information: http://wiki.dare.nl/wiki/index.php/SQL_ ... _on_tables.
When such SQL keywords are used it should be possible the have the data in a suitable format.
