				Printout of redused emission (peak) table
				Posted: 18 Jan 2017, 13:25
				by heutink
				Want to make a peak table with redused column information. The keyword "EMISSION TABLE" is working. Can't find the correct keywords to generate this table. What is wrong in the  keywords beneath (see file attachment).
				Re: Printout of redused emission (peak) table
				Posted: 18 Jan 2017, 17:06
				by mahe
				I was able to find the ||1|SELECT ALL FROM PEAKTABLE|| keyword on the Radimation manual at
http://wiki.dare.nl/wiki/index.php/Chapter_13
This keyword contain a prefix (||1|) which retrieves the table from a test called "1". In order to make this keyword work with a test named differently, the 1| prefix must be either renamed or removed. (The prefix is now removed from the manual)
Your used keywords should work without the prefix.
||SELECT NR,PEAK NR,FREQUENCY,PEAK,QUASI-PEAK,[QUASI-PEAK LIMIT],[QUASI-PEAK DIFFERENCE],STATUS,ANGLE,HEIGHT,POLARIZATION FROM PEAKTABLE ORDER BY FREQUENCY|| ||RUNMACRO(AUTOFITTHISTABLE)||
				Posted: 19 Jan 2017, 16:21
				by heutink
				Thanks for the code. However it stills not working. The complete table is written to the generated report document.
Attached two files:
Template document as input for report generator: REmultiband.docx
Generated report document: 6143301.4.1.1.docx
Also during generation of the report the report generator complains about keyword "". I just skipped it during report generation. What could this be, i can't find it in the template document.
				Posted: 19 Jan 2017, 17:13
				by mahe
				The select command can be used to print the full table:
Or selecting only a few columns:
||SELECT [PEAK NR],FREQUENCY,PEAK,[PEAK LIMIT],[PEAK DIFFERENCE] FROM PEAKTABLE|| ||RUNMACRO(AUTOFITTHISTABLE)||
The second table code in your template does not contain the: "FROM PEAKTABLE||" part.
I have placed the Table code in a Word table so the generator will make a table with lines in it. See attached modified template.
