How can I include used equipment in a report
james
Post by james »
I would like to include the description of the used LISN in a report, what code can I use?
Re: How can I include used equipment in a report
To include the used equipment use the code
||EQUIPMENT TABLE||
This will include a table with all used equipment including a header containing the field names.
To only include specific devices it is possible to use SQL and filtering. For example, to only show devices of type LISN use:
||SELECT DESCRIPTION FROM [EQUIPMENT TABLE] WHERE [DEVICE TYPE] = "LISN"||
This will output the used LISN with the header "Description".
To only output the description of the first LISN device, use the following report generator code:
||LISN 1 Data Description||
Example to output the description for an Injection device:
||Injection device 1 Data Description||
tha-paul
Post by tha-paul »
dear all,
at the end of a report, I want to have a summary of all used equipment. Is this possible?
If i use ||Equipment Table|| it will only print the equipment of a selected test.
Is it also possible, to have the calibration dates in that equipment list?
It is not possible at this moment to combine the list of equipment from multiple tests into a single table.
Putting multiple separate tables (one for each test) under each other is sadly the best what we can suggest at this moment.
I do understand your request, and I agree that it would be a benefit if all the equipment that is used in the report is listed in a single table, even if some devices are used in multiple tests.
I have created a new wish for this request: #12373: Possibility to have a single table of equipment in a report for multiple tests.
For the request to include the calibration date, we already have an existing ticket:
#4666: The calibration expire date should be included as a column in the Equipment table for the report generator
