For each test it is possible to add tsf files directories to categorize per standard as example. Only in the "TSF_file" directory of Radimation these directories have a general name like "New Directory-x" ( x is a number from 1 to ....). Is it possible to re-name these directories to more specific names (as example equal to the "Description" name in the TSFDIR.INI file). We want to synchronise the tsf file data of several laptops with each other.
Is it correct that we only have to change the directory name and the "path" name in the corresponding "TSFDIR.INI"file.
Why not copying the "Description" name also in the "Path"name of the TSFDIR.INI file. Is there reason to do it as it is.
Re-name sub directories
Re: Re-name sub directories
We do not recommend to manually change directory names or files within the TSF_File directory, using the Windows Explorer.
But if you really want, it is indeed possible to rename the directories, if you also correctly update the 'Path=' and 'Description=' in the TSFDIR.INI file.
Please be aware that manually changing the content of the TSF_File directory is not supported by us. We strongly recommend to make a backup, before you make manual modifications. Also it is advised to close RadiMation before you make modifications.
