This version 2025.2.10 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at, for example, a separate PC or laptop with your setup and measurement equipment, before you are going to use it for daily operation.
The new 2025.2.10 release of RadiMation can now be downloaded from the Raditeq website.
We always advise to thoroughly test each new RadiMation software version to determine if it works correctly in your situation with your equipment, before you use it for daily measurements. This is also a requirement for ISO 17025 accredited test laboratories. To enable customers to validate new software versions before implementing them, we have made it possible to install multiple versions of RadiMation side-by-side on a single PC. It is, of course, also possible to perform this validation on a separate PC or laptop.
The following issues are fixed or improved in this 2025.2.10 version (compared to the 2025.2.9 version):
- #6834: Preserve the contents of device driver INI files used in test results
- #16266: Ensure all logs are written before closing the RadiLog database connection
- #16726: Improve report generator inclusion of polarization-specific graph lines
- #17074: Simplify the controls for selecting the test continue state to a single spin edit control
- #17116: Fix unknown error descriptions for the IMU-MGS
- #17123: Improve measurement speed of the R&S MXO
- #17203: Limit the length of the "Note" text to 32767 characters
- #17213: Add the "INTERNAL PREAMPLIFIER MODE" keyword for multiband tests
- #17218: Fix graph axis configuration when using the scaling menu shortcut
- #17219: Ensure the Excel report generator inserts new worksheets next to the previously inserted worksheet
- #17252: Fix rounding issues when calculating logarithmic receiver resolution
- #17253: Allow pulsed immunity multiband EFT and Surge tests to be restarted
- #17289: Set the default measurement frequency for VI window tests to 50 MHz
- #17292: Prevent deleting device driver entries from the test-site configuration using the Delete key while in read-only mode
- #17294: Calculate sweep time per MHz also for frequency spans smaller than 1 MHz
- #17319: Allow singleband tests to include "Auxiliary equipment" in the test-site configuration
- #17403: Ensure virtual instruments are correctly deinitialized when an error occurs
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2025.2.
