New version: RadiMation version 2013.1.19
Today we released a new version of RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2013.1.15 version.
Since the 2013.1.15 version, we also created some internal builds, which haven't been made public. That is the reason that the 2013.1.16 up to the 2013.1.18 version are not available.
The following issues are fixed in this 2013.1.19 version (compared to the 2013.1.15 version):
  • #2541: RF setting of the marconi 2023 does not check for errors
  • #4352: Driver: device driver check Marconi 2022 (ID1343) doesn't check anything
  • #4594: Limited Signal power is never adjusted anymore in Multiband
  • #4905: Test data of some previous versions are corrupted and can't be opened anymore
  • #4930: Driver: Bonn amplifier BLWA 0810-400
  • #4936: Changing AT polarization does not seems to work
  • #4954: Where to define Cables for the EFT testing
  • #4967: How to configure switch matrix changes
  • #4968: Driver: HI4433LFH Holaday field probe
  • #4969: CANoe interface object not initialized correctly
  • #4970: Marconi 2023/24 error: Measurement using PM is not possible
  • #4972: AR FP3000A is not responding
  • #4973: RadiSense CTR1001A IV error unknown command
  • #4976: Stop button doesn't work in Network Analyzer system calibration
  • #4977: Report generator raises index error for S-parameter test
  • #4978: Export of graph data to excel is not using the correct comma
  • #4979: Phase information is not retrieved from the R&S ZNB
  • #4982: Driver: Amplifier Research AT4510
  • #4985: Driver: AR 60S4G8
  • #4986: Driver: AR 40S1G4
  • #4987: Driver: 350S1G4
  • #4993: Calculate the RMS value of a Burst measurement
  • #5020: ESI26B Spectrum Analyser Query unterminated error
  • #5021: R&S ESIB 40 receiver Query unterminated error
  • #5023: SMY-01 PM with ext blanking
  • #5024: Option window to Enable software configuration EMCO2090 is not shown anymore
  • #5030: R&S SME: Device driver should use 0.01 dB Output resolution
  • #4944: Extend R&S ZNB driver to be used during antenna calibrations
  • #5028: R&S SME: Use fixed attenuator mode to reduce attenuator relais switching
  • #1368: Use blanking input for SMY02 PM modulation
  • #4062: R&S SMY-01 input blanking for pulse modulation
  • #4255: Driver: strange VBW value is set
  • #4256: Calibration asks for resistor and shows voltage level
  • #4260: Measuring deviations despite correct .CAL
  • #4267: Starting Level Signal Power can trigger RF power on without interlock
  • #4273: Power meter is read continuously with modulation applied in Manual Mode
  • #4547: Setting the reference level has no effect on the ESMI
  • #4548: Can select only one peak at the time
  • #4592: Powermeter virtual instrument is not always unloaded from memory
  • #4616: MXE alignment issue and is not released from remote
  • #4842: Graph lines from a previous VI Powermeter window are still shown under the 'Graphs' button
  • #4932: Driver: Injection device FCC F51
  • #4992: Configure a maximum of 360 degrees for a Manual Controlled Turn Table
  • #4995: Customization of the Graphline color in the Powermeter window is not working
  • #5008: Dropdown of the threshold level for a burst test is using an unlogical order
  • #5022: Innco CO3000 is started at 100cm instead of 90cm
  • #5037: RG error when requesting the Equipment Table information
  • #5047: Pulsed Immunity explanation
  • #5054: Mil Std CAL text is not completely visible
  • #5059: Innco CO3000 control multiple devices with one GPIB address without addressing
  • #5064: 18-channel AD-convertor device driver for the RadiSense to be used during justation
  • #5067: Agilent 8753ES can't change GPIB address
  • #4843: Envelope trace mode for a RadiPower is not working anymore after a Burst mode measurement
  • #4929: Driver: R&S HCC turntable + absorbing clamp controller
  • #4996: Last bursts in a powermeter burst graph is showing a higher value
  • #4999: Long burst measurements with the RadiPower will result in not enough memory errors
  • #5061: Invalid buffer mask Agilent N9010A Scanning Receiver over USB (VISA Alias)
If you have specific questions regarding on of the above items, please contact us at support@radimation.com
No changes have been made to the measurement algorithms and correction calculations.
Several improvements and new functionality is included in this 2013.1.19 release, most important are:
  • Several updates in the device drivers, to control more EMC Equipment
  • Fixes for the loading of old measurement data in the newest version
  • Several improvements in the S-parameter test
  • Major improvements in the RE Burst measurement
  • More optimizations (faster, less memory) in the RadiPower measurements for EN300328
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2013.1.
The new 2013.1.19 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
