New version: RadiMation version 2026.1.3
Posted: 31 Jul 2026, 14:48
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2026.1.x BETA versions.
This version 2026.1.3 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2026.1.3 release of RadiMation can now be downloaded from the Raditeq website.
The following issues are fixed in this 2026.1.3 version (compared to the 2026.1.x version):
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2026.1.
- #14469: Graph customisations no longer contain duplicates
- #15809: Update Devexpress
- #15932: Remove Microsoft.Experimental.Collections dependency
- #15933: Replaced the diagram control for the UFA calculation
- #16461: Fix "<filename> is being used by another process" error when inserting picture contents into generated report
- #16546: Fix Directories in Configuration form sometimes appearing empty
- #16562: Fix button "Add [Device Type]..." not appearing in Devices bar
- #16568: Device drivers can now send text containing any special characters
- #16598: Update InnoSetup to 6.7.0
- #16598: Use HTTPS connection to download the latest DRIVERS.EXE during setup
- #16631: Fix hand cursor not being shown when hovering over graph data points
- #16640: Fix tests in a running sequence appearing in the wrong order
- #16718: Update Devexpress
- #16763: Fix incorrect saving of changes from "Graph axis scaling" dialog when "OK" is pressed
- #16782: Improve turntable control for emission testing
- #16833: Provide clear guidelines on when the EUT needs to be opened to start the test, or, conversely, when all documents need to be closed to start system calibration.
- #16839: Pulsed immunity coupling configuration now restores the previous selection
- #16860: DevExpress update to 25.2.7
- #16888: Allow the limit line in the table export of the graphline to have no data at points that do not fall under that limit line
- #16892: Optimise memory usage when creating a report with many graph lines containing numerous traces
- #16907: Fix inability to insert a row at the beginning of the limit line table
- #16952: Fix graph customisations to be saved in the test result
- #16978: Fix "Max Peak" sometimes appearing alongside "Horizontal/Vertical/Both Max Peak" during continuous peak measurement
- #16979: "Peaks to maximum" no longer changes the order of the peaks
- #16980: Fix points on the right side of the graph disappearing during continuous measurement
- #17005: Update file archive compression module
- #17129: Reseller: Shenzhen Itestin Technology
- #16856: Fix multiband absorbing clamp emission amplitude calculations
- #16726: Improve graph inclusion by the report generator for polarization specific graph lines
- #17138: Reverted change for multiband absorbing clamp emission amplitude calculations
- #17143: Improved Application Note 153: Multi Axis Field probe corrections
- #17180: Device driver: Pearson Electronics 8590C curent sensor
- #17214: Fix line coupling-related report generator keywords not working
- #17228: Don't try to invoke an action on a form that may have already been disposed
- #17230: Remove an unexpected character included in the line identifiers for the NX series 1PH coupling line selection.
- #17246: Don't try to invoke an action on a form that may have already been disposed
