New version: RadiMation version 2025.1.10
Posted: 07 Aug 2026, 15:17
by Jeru
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2025.1.10 version.
This version 2025.1.10 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2025.1.10 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2025.1.10 version (compared to the 2025.1.9 version):
  • #16496: Maturo MC32 communication improvements
  • #16771: Improve selection of to be inserted graph lines by the report generator
  • #16783: Drivers for the EMC-Partner IMU-MGS 4000 are available.
  • #16810: Allow clicking of the left-most data points on the graph
  • #16908: Drivers TESEQ CBA 125E 250E 500E
  • #16988: PMM ER800 attenuation is now correctly included in the test.
  • #17003: Read additional responses returned by the CBA-1G-600D
  • #17025: Read additional responses returned by the CBA-1G-600D
  • #16830: Allow clicking of the left-most data points on the graph
  • #17044: Do not hide ampersands in device brand names on the auto-detection wizard results page
  • #17051: Siglent SSA now updates the measurement span when used as power meter
  • #17052: Add drivers for Raditeq RSR2118S, RSR2126S, RSR2140S, and RSR2160S field probes
  • #17076: SSA3015X now applies sweep time as EMI detector measure time if not set before in EMI mode
  • #17086: Restore the selected RBW when switched to EMI mode
  • #17091: Add Top-Precision turntable and antenna tower drivers
  • #17094: Do not trigger an error when there are no graphlines available
  • #17124: Add Siepel stirrer device driver
  • #17150: Test information items are now available in device drivers
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2025.1.
