This version 2026.1.4 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation on, for example, a separate PC or laptop with your setup and measurement equipment, before you are going to use it for daily operation.
The new 2026.1.4 release of RadiMation can now be downloaded from the Raditeq website.
We always advise to thoroughly test each new RadiMation software version to determine if it works correctly in your situation with your equipment, before you use it for daily measurements. This is also a requirement for ISO 17025 accredited test laboratories. To enable customers to validate new software versions before implementing them, we have made it possible to install multiple versions of RadiMation side-by-side on a single PC. It is, of course, also possible to perform this validation on a separate PC or laptop.
Fixed issues and improvements
The following issues are fixed or improved in this 2026.1.4 version (compared to the 2026.1.3 version):
- #6834: Preserve the contents of device driver INI files used in test results
- #14995: Add monitoring input support for NX-series Surge and EFT generator-specific parameters during active sequences
- #15181: Add monitoring input support for NX-series Surge and EFT generator-specific parameters during active sequences
- #16266: Ensure all logs are written before closing the RadiLog database connection
- #16282: Add monitoring input support for NX-series Surge and EFT generator-specific parameters during active sequences
- #16384: Improve loading speed of advanced device driver settings panels
- #16676: Texts from device drivers now use the language configured in RadiMation
- #16896: Add a time-domain scan configuration panel to the R&S ESW device driver
- #16893: Add a flag to the Lumiloop INI settings to disable frequency transmission
- #17000: Migrate from Crypto++ to Botan
- #17081: Fix sequence progress calculation for the KeyTek EFT generator driver
- #17083: Fix graph insertion from test-specific Excel templates
- #17117: IMU-MGS Surge disables multiple line selection to prevent testing more lines than expected
- #17118: IMU-MGS Surge now disables multiple line selection to ensure only the expected sequences are tested
- #17193: Add device driver for Tektronix AFG31252
- #17196: Add device driver for Solar SE 2925-1 calibration jig
- #17198: Add device drivers for ETS-Lindgren antennas 3109, 3106B, 3115, and 3116
- #17203: Limit the length of the "Note" text to 32767 characters
- #17206: Select the correct CDN-A lines during Surge testing with the IMU-MGS
- #17210: Fix pulsed immunity TSF settings validation
- #17213: Add the "INTERNAL PREAMPLIFIER MODE" keyword for multiband tests
- #17217: Add device driver for R&S NRP8E
- #17218: Fix graph axis configuration when using the scaling menu shortcut
- #17219: Ensure the Excel report generator inserts new worksheets next to the previously inserted worksheet
- #17225: Fix setup of the external IMU-MGS CDN-A coupling device
- #17234: Convert the R&S SMIQ driver to use device streams
- #17235: Improve GPIB SRQ handling when a low-level callback arm error occurs
- #17238: Implement pulse-train modulation support in RadiMation for Keysight/Agilent N5173B/N5181B signal generators
- #17254: Add 100 kHz as a selectable EFT pulse repetition rate
- #17263: Add device driver for Boonton 4241
- #17266: Fix GPIB EARM handling
- #17275: Prevent applying user corrections to RadiSense probe models that do not support them
- #17276: Prevent the R&S MXO driver from rounding device-reported frequency limits above the supported maximum
- #17268: Fix an issue where the minimum RBW of the R&S MXO was not correctly updated after leaving automatic RBW mode
- #17279: Improve R&S MXO spectrum acquisition stability and zero-span handling
- #17281: Fix Prana persistent connection initialization
- #17282: Add monitoring input support for NX-series Surge and EFT generator-specific parameters during active sequences
- #17286: Fix RBW not being correctly restored when switching between device modes
- #17289: Set the default measurement frequency for VI window tests to 50 MHz
- #17291: Fix incorrect sweep time configuration for the R&S FPC series in multiband conducted emission tests
- #17293: Set the default measurement frequency for VI window tests to 50 MHz
- #17294: Calculate sweep time per MHz also for frequency spans smaller than 1 MHz
- #17295: R&S FPC now performs detector measurements in parallel instead of sequentially
- #17297: Improve parsing of the legacy scan mode data format used by the R&S FPC series
- #17301: Maintain the logical list selection in graph customization settings
- #17305: Fix calculation of fixed-count steps per decade to prevent getting stuck while searching for the initial frequency of the range
- #17306: Fix timeout issues when reading trace data from the R&S MXO
- #17308: Fix display of graph lines with polarization-specific filtering
- #17311: Improve low-frequency measurement execution for the R&S MXO series
- #17316: Use a default extended tolerance of 5% when the IEC 61000-4-20:2022 calibration method is selected
- #17317: Preserve configured UFA calculation values immediately when changed
- #17319: Allow singleband tests to include "Auxiliary equipment" in the test-site configuration
- #17320: Change the background color of point groups in UFA calculation results to transparent
- #17327: Add device driver for Vectawave VBA400-260
- #17329: Update the reverb validation TSF screenshot in chapter 5 of the manual
- #17340: Optimize the INNCO 3000 antenna tower and turntable device driver
- #17347: Include data from multiple bands when exporting data as an ambient limit line
- #17348: Restrict "Speed control" values to the allowed range
- #17349: Add device driver for COM-POWER LI-3P-263
- #17350: Add device driver for COM-POWER ACL-6000
- #17351: Add device driver for COM-POWER AL-130R
- #17352: Add device driver for Vectawave VBA250-120
- #17353: Add device driver for COM-POWER CLEM-6146
- #17354: Add device driver for COM-POWER ADA-515-CLEM
- #17355: Add device driver for COM-POWER CLCE-227
- #17356: Add device drivers for COM-POWER CDNs
- #17358: Add device driver for Vectawave VBA1000-350S
- #17359: Add device driver for Vectawave VBA1060-125
- #17369: Include negative contact notes in ESD report tables
- #17370: Add device driver for EMSense 7007-211
- #17373: Verify that the R&S EPL has finished processing data after reporting scan completion
- #17374: Fix shared device stream handling for NX-series generator drivers
- #17377: Fix singleband emission chamber tests using frequency lists
- #17378: Retry requests to Netatmo servers when a request fails
- #17388: Fix retrieval of factory calibration data from RadiSense 3000
- #17393: Improve R&S MXO series measurements below 10 Hz
- #17394: Fix Milmega AS0860 amplifier incorrectly reporting that it is not in operate mode over RS232
- #17398: Prevent the Siglent SSA5058A from switching to GPSA mode when already operating in GPSA mode
- #17403: Ensure virtual instruments are correctly deinitialized when an error occurs
- #17405: Add device driver for Solar 9867-5-TS-50-N
- #17406: Add device driver for Rohde & Schwarz RTM3004 oscilloscope
- #17407: Fix Netatmo driver crash in RadiMation
- #17411: Implement speed control for the Frankonia FC05 turntable
- #17414: Replace LNG file dependencies with inline strings
- #17415: Fix amplifier linearity data display when opening a file or starting a test
- #17423: Fix IMU-MGS 4000 Surge angle synchronization when using the external CDN-A
- #17445: Fix IMU-MGS 4000 Surge angle synchronization when using the external CDN-A
- #17457: Add ARB/AWGN support for the R&S SMBV100B
- #17460: Include the "Extended alignment needed" setting when determining whether alignment is required
- #17463: Enable EUT mains for the AXOS EFT generator when using external coupling
- #17465: Update device initialization order for pulsed immunity generators
- #17467: Fix the ability to close a window by double-clicking its icon
- #17482: Remove remaining Crypto++ references
- #17508: Fix N9961B driver option 233 validation
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2026.1.
