The following issues are fixed in this 2016.1.12 version (compared to the 2016.1.11 version):
- #1784: Agilent E4416A/E4417A (EPM-P series) should have option to measure Peak power
- #5629: Include option to 'Run Radimat.exe' after Device Drivers setup program
- #7080: Driver: EM test CWS 500N2.2
- #7099: Changing Powermeter advanced Measure setting is not enabling other settings when only the value is changed
- #7301: Driver Messtechnik Motion detection system
- #7475: Extend Field sensor device driver configuration with advanced Monitoring measurement settings
- #7476: Wrong measurements at first frequency point of the test
- #7615: Does the driver of the Power meter E4417E performs reading of the peak value?
- #7641: Measurements take a long time with the Advanced ESU 40 / FSV as a powermeter
- #7650: Voltage test level Voltage measurement (Powermeter) is not measured
- #7659: Agilent N5182A error the measurement device does not support this functionality
- #7666: Driver R&S EZ17 current probe
- #7668: Driver: Schaffner/TESEQ CDN S150
- #7669: Driver Schaffner/TESEQ CDN USB/p
- #7672: Driver: MEB CDN S25
- #7673: Driver: MEB CDN S1/50
- #7674: Driver MEB CDN MEB KEMZ801
- #7676: Driver: Switch matrix HP3488A
- #7677: Driver: NRP8SN
- #7678: Driver: Directional Coupler RFPA RFC801000 -40-150
- #7679: Driver: Directional Coupler RLC CHP-1040-D-40-40-FF
- #7681: Driver CDN Schaffner USB/c
- #7683: Driver CDN Teseq M116
- #7684: Driver: NRP8 Power meter
- #7698: EM Powermeter unable to pass the checkdevice.
- #7702: Driver: ETS-Lindgren's 8100-045 RF Power Amplifier
- #7703: Driver: Werlatone C10762 Coupler
- #7704: How to use a manual Turn Table during Multiband Emission?
- #7709: Sensata Olimex SENT (Configurable AD Converter) Timeout before operation completed
- #7710: Spectrum Analyser (ID1465) Input 2 (LAN): SPecific System Error: -410, "Query interrupted"
- #7730: False graph of result of N9000-series measurement: High emissions
- #7739: Agilent E4417A Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO)
- #7747: EMTest UCS500N + Phase 3 coupler Error
- #7749: SetEndOfString is not used
- #7762: Ability to use the Configurable AD Converter for PMX
- #7771: R&S ESI as powermeter is measuring too fast
- #7772: The measure time is not always correctly set when the receiver is used as a powermeter
- #7774: Correction of resistor is not used in magnetic field measurement
The new 2016.1.12 release of RadiMation can be downloaded from the DARE!! web-site:
![Image](http://wiki.dare.nl/wiki/images/b/b0/Download-button.png)
