New version: RadiMation version 2021.3.9
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2021.3.3 version.
This version 2021.3.9 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2021.3.9 release of RadiMation can now be downloaded from the Raditeq web-site. Image
The following features are added to RadiMation 2021.3
  • #12005: Device driver for EM-Test NX7 with DCD(5-A b-8-4) Burst coupling network
  • #12760: LISN R&S ENV4200
The following issues are fixed in this 2021.3.9 version (compared to the 2021.3.8 version):
  • #12591: Communication streams show different behavior when an Option string containing only a newline is returned by the RTO
  • #12592: RTE1024 vertical resolution optimizations
  • #12625: External component exception when using the Tabor WW5601
  • #12645: Voltage Dips test
  • #12666: SMCV100B problem reading very long option strings
  • #12667: FSIQ 7 Expected IDN response does not match the IDN of the device
  • #12675: Report generator issue - RI E-Field closed loop
  • #12676: NRP CheckDevice results in force close of RadiMation
  • #12680: Object reference not set to an object when a SB test is continued
  • #12687: About CS114 test
  • #12708: Incorrect control of analyser
  • #12721: Write application note: How to use Remote Visa to control devices connected to other machines on the network
  • #12730: SMCV100B: Only lock the user input instead of the entire GUI during remote control
  • #12735: Sequence contains no elements during creation of correction file.
  • #12741: RTE1024 driver error - undefined header
  • #12749: Test file extension number ordering does not seem to match file last modified date
  • #12753: Prana amplifier does not switch mode when remote controlled
  • #12759: Questionable values (P fwd & P sig) in RadiMation 2021.2.7 (compared to earlier values)
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2021.3 .
