New version: RadiMation version 2025.1.4
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2025.1.3 version.
This version 2025.1.4 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2025.1.4 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2025.1.4 version (compared to the 2025.1.x version):
  • #8655: GTEM correlation graph is now also shown when an ambient suppression line is present
  • #9118: GTEM correlation is now also calculated when ambient suppression is present in multiband emission GTEM test
  • #10837: Multiband GTEM is now quicker as x y z position has not to be rotated many times
  • #15027: Final measurement of GTEM Peaks is optimised to measure all frequencies of a given axis first
  • #15258: Placing of the EUT in the GTEM test is now optimized
  • #16214: The amount of EUT repositions required for GTEM testing is reduced
  • #16311: Fix collection modified error
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2025.1.
