New version: RadiMation version 2025.2.9
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2025.2.8 version.
This version 2025.2.9 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2025.2.9 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2025.2.9 version (compared to the 2025.2.8 version):
  • #15653: Improve report generator inclusion of polarization specific graph lines
  • #15757: Driver: TDK VSI-1000 Field probe positioner
  • #16941: Angle plots now only show the data for a single selected peak
  • #17071: Fix Prana N-DT amplifier switches back to off state if multiple instances are shown on the amplifier control window.
  • #17077: MXO driver updates the expected measurement time when used as voltage measurement device in immunity tests
  • #17092: R&S MXO now allows selecting a 1 Hz RBW
  • #17101: Model number of non-existing Raditeq RSR2018S is updated to RSR2118S
  • #17111: Improve DAO databse device driver
  • #17115: Add missing coupling lines for the IMU-MGS
  • #17132: Allow selecting a specific RBW for analyzer voltage measurements using the test information items
  • #17151: Fix error when reading CSV database
  • #17166: R&S FSL 6 do not send auto sweep time in zero span
  • #17168: Allow retrieving multi axis field results with the RSS1006A >= FW 5.02
  • #17169: R&S ESU first query the active input before changing it
  • #17228: Don't try to invoke an action on a form that may have already been disposed
  • #17229: Fix for software update of RSS2010 via RadiMation
  • #17245: Fix default start and stop frequency used by the R&S EPL and FPL series
  • #17246: Don't try to invoke an action on a form that may have already been disposed
  • #17248: IMU-MGS support polarity alternation and fix coupling selection
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2025.2.
