Generating an invoice with the report generator?
Is it possible to use the Report Generator in RadiMation, to generate an invoice for the measurements for my customers?
The to be generated invoice is not related to any of the performed tests, so how should I use the report generator to be able to generate the invoice?
Does anyone have a suggestion for this?
Re: Generating an invoice with the report generator?
It is indeed possible to make use of the Report Generator in such way that it will help you to automatically generate an invoice.
What you can do is edit your report template in such way that it does not contain any specific test keywords anymore.
It is possible to obtain all kind of information (client information, test site, manufacturer) that is needed for creating the invoice.
It is also possible to create extra information fields under "EUT Information", e.g. invoice costs or total hours etc.
For example the information can be inserted in the Invoice template with the keyword ||EUT|INVOICE1||, where INVOICE1 is the name of your added information data.
More detailed information about the report generator:
General information:
http://wiki.dare.nl/wiki/index.php/Chapter_13
Use of keywords:
http://wiki.dare.nl/wiki/index.php/Test ... sion_codes
Test specific report generator templates:
http://wiki.dare.nl/wiki/index.php/Test ... _templates
Attached an example of an invoice template.
Invoice template_forum.docx
(16.73 KiB) Downloaded 916 times
