New version: RadiMation version 2013.1.15
Today we released a new version of RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2013.1.14 version.
The following issues are fixed in this 2013.1.15 version (compared to the 2013.1.14 version):
  • #1680: The resolution for the reflection coefficient should be increased from 0.001 to 0.0001
  • #2232: Device driver to control the R&S ESI(B) series analyzers/receivers over LAN
  • #2758: ZVK measuring times are not inserted in side the machine, it is always 1 sec.
  • #4041: Antenna mast Frankonia FC 02 not working
  • #4324: Error Advantest TR4172 not all bytes are written to the GPIB
  • #4464: Driver: tracking generator R&S ESPI3 receiver with option FSP-B9
  • #4554: R&S ESPI7 ethernet communication
  • #4658: Network analyzer measurement: Swap noise and full through measurement
  • #4659: Network analyzer measurement: Support Full 1 port measurment, which only measures a single port
  • #4687: Strange graphs are included in the report if the frequency has been changed to an already tested frequency in RI Single band manual mode
  • #4689: Emco 2090 is controlled with an offset
  • #4804: Simultaneously remote control LISN ESH3-Z and use Spectrum Analyser of R&S ESAI/ESMI doesn't work
  • #4904: No graphical display of results and no results are stored
  • #4911: Help Technical Support items are not working
  • #4912: Advantest TR4172 is not using Video Average detector
  • #4913: Wrong dates are shown in the EUT window
  • #4915: Antenna tower limits are not retained for the EMCO2090
  • #4917: Driver: R&S ZNB 40 Network analyzer
  • #4918: RadiSense 4.51 probe is not correctly detected
  • #4920: Configuration of magnetic field substitution test level is problematic
  • #4921: Unhandled exception after finishing RI substitution tests
  • #4922: SMA100A not working correctly
  • #4925: Powermeter measurement with the R&S FSP below 300 Hz measures the zero feed through signal
  • #4927: Driver: pre-amplifier Teseq LNA 6901
  • #4928: Driver: pre-amplifier R&S AFS
  • #4931: Driver: Injection device Mess Electr NNBM8125
  • #4937: StandardDetails window is not automatically resizing
  • #4939: Default Address Information screen text is cut off
  • #4946: Text in Calibration Import window not completely visible
  • #4949: Does RadiMation support time domain scan
  • #4951: Is it possible to use a calibration file at 20vm to generate a field of 3vm
  • #4956: How can we run 5.8.38 and 2013.1.15 on the same PC
  • #4957: Files generated in 2013.1.15 are not readabel in 5.8.38
  • #4961: How to add attenuators for calibration
  • #4971: How and with which RM version can we control the power meter RPR3006P?
  • #4980: The 'number of sweeps' setting in a network analyzer test is not working
No changes have been made to the measurement algorithms and correction calculations.
Several improvements and new functionality is included in this 2013.1.15 release, most important are:
  • R&S ESI-based drivers are now able to be controlled over Ethernet
  • Activate Tracking generator option is available for ES-based drivers
  • Issues with a 1 cm offset in antenna tower heights are fixed
  • Problems with showing of the graphs of 200 Hz RBW measurements
  • Correct remote control of the LISN if it is controlled by a R&S analyzer
  • More device drivers for EMC equipment
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2013.1.
The new 2013.1.15 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
Reason: Updated list of fixed items
