New version: RadiMation version 2013.1.23
Today we released a new version of RadiMation software, which includes a lot of improvements and fixes for problems that have been detected since the release of the 2013.1.21 version.
The following issues are fixed in this 2013.1.23 version (compared to the 2013.1.21 version):
  • #4059: Axis selection for the FI7000
  • #4584: Signal generator HP 83752A is not set for modulation
  • #5119: Report generator code: FORWARD POWER LIST is not exporting any data
  • #3834: If overload check for receiver, not scanning receiver
  • #4212: Adjustments (advanced) settings have no effect with calibration power sensor (4418)
  • #4372: Test information time is incorrectly set
  • #4739: Report Generator: time, date and special character is wrong
  • #4820: Test data can't be opened, error 'No data document could be created for the test identifier'
  • #4897: RadiMation is not responding when the Database connection location is opened
  • #4935: Driver R&S unit SCIU
  • #5050: Manual mode frequency adjustment (arrow button) is pressed multiple times
  • #5056: During test it is not possible to add or remove graph lines
  • #5057: Settings to change graph line colors are not retained
  • #5070: R&S SMA 100 device driver check crashes RadiMation
  • #5073: R&S HCC should read a limit during a check to ensure that the correct device is connected
  • #5074: Word report generator can cause an exception caused by delayed unloading
  • #5076: Graphs button is disabled during a multiband immunity test
  • #5106: Driver: Schaffner/Chase CBL6111D antenna
  • #5108: Driver: HP 59307A switch matrix
  • #5109: Driver: AR 1000LM24 Amplifier
  • #5110: Driver: AR 500W1000M3 Amplifier
  • #5120: Error from RadiPower is not correctly reported
  • #5122: Driver: R&S unit SCIU switch matrixes
  • #5124: RPR2018C timeout errors
  • #5130: RadiPower can become suddenly unresponsive
  • #5131: Incorrect resizing is causing unreadable items RPR3006W
  • #5132: Wrong times are shown in the eventlog of a calibration
  • #5134: RadiTower stays in Remote after test is closed
  • #5135: Control of the RadiTower enters an endless loop
  • #5138: Add possibility in the Maturo device driver to select the device unit
  • #5139: Driver: R&S FSEA as powermeter
  • #5145: Wrong ranges of Holaday HI 4433-MSE field probe
  • #5147: R&S unit SCIU Amplifier isn't going to operate
No changes have been made to the measurement algorithms and correction calculations.
Several improvements and new functionalities are included in this 2013.1.23 release, most important are:
  • Start and stop times of the test are now correctly detected and reported
  • Crashes caused after the generation of a Microsoft Word report
  • The color of graphlines (and limit lines) is not lost anymore
  • Incorrect sizing of the windows is fixed on the Chinese Windows OS.
  • Possibility to specify the monitor measuring parameters for the field strenght sensor and the powermeters
  • Fixed problems with the Up/Down arrows behind input boxes
  • Improved control of Radi* equipment
  • The graph can be changed again while a test is running
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2013.1.
The new 2013.1.23 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
