New version: RadiMation version 2016.1.3
We have released a new major version of the RadiMation software, which includes several improvements and small fixes for problems that have been detected since the release of the 2015.2.4 version.
This version 2016.13 is the new major version that has been validated at DARE!! Measurements for two weeks. During this two week period no problems have been found. We however strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The following issues are fixed in this 2016.1.3 version (compared to the 2015.2.4 version):
  • #470: No buttons present for often used operations
  • #510: No overview of of used equipment at start of a test
  • #940: Predefine which graphs should be shown on the screen
  • #3826: Show during measurement option in the graph line configuration window
  • #4162: automatically add and show the configured and selected ad channels in the graph window during an RI measurement
  • #4613: Calibration expire window should be a MDI client window
  • #4641: Switching between graph and table should rename graph button to table info
  • #5125: Closed loop measurements
  • #5527: Label of Show details button should become Hide details when details are shown
  • #5576: Driver: R&S OSP130 with option B102
  • #5607: Add "Save Calibration As..." possibility
  • #5661: Add Frequency range panel for Bonn BLWA drivers
  • #5678: Enhanced status window description of vertical and horizontal is not directly clear
  • #5985: ESR7 replies with error about AC_DC coupling on Channel2
  • #6020: Show all activated AD-channels by default in the graph during a test
  • #6027: Perform final measurements in EMI receiver mode with the Agilent MXE N9038A EMI receiver
  • #6036: Ability to enter manual information at each disturbance frequency
  • #6090: Start/stop time test fileds are not retained from 2014.2.12 to 2015.1.7
  • #6123: RadiMation is not responding when Amplifier Control window is enabled
  • #6251: R&S ESR7 specific System Error: -222 Data out of Range DISP:TRAC:Y:RLEV:0.0103DBM
  • #6270: Raise an error when R&S NRP-Z55 power sensor is disconnected during test
  • #6296: Device stream in the device driver system for http protocol using get and post
  • #6297: Driver: USB-xSPDT-A18 series switch matrix
  • #6299: R&S FSP30 spectrum analyzer option for FFT filters
  • #6302: Driver: Tektronix RSA5100-series
  • #6312: Timeout in communication with R&S ESPI after QP measurement
  • #6321: Clear the input buffer of a configurable device driver directly after the connection is established
  • #6322: Not possible to specify the Escape character in the configurable device driver
  • #6323: Configurable switch matrix device driver sends the 'Turntable Changed' command before the turntable starts moving
  • #6337: Turning off Pre-amplifier option (INP:GAIN:STAT OFF) without this option being available is raising an error for the R&S FSV
  • #6340: No Unit is shown for test level
  • #6343: Ability to disable determination of the dynamic range during the Attenuation / Gain system calibration
  • #6345: Carrier Level command of the Configurable Signal generator is not transmitted if no Carrier On command is specified
  • #6349: Driver Switch matrix ICS 4864
  • #6354: QP Detector Measuretime of ESL6 is set to 10 ms
  • #6360: Driver: Tektronix 2001 for fixed voltage test
  • #6361: Ability to zoom in the frequency graph during the prescan phase of a MB Emission test
  • #6362: Frequency of the graph in the report is different
  • #6364: Too few spaces in the name of the graphline in a report generator code causes that the graph is not include in the report
  • #6389: Update the Configurable Switch Matrix wiki knowledgebase page
  • #6394: NI DAQ USB 6218 AD Converter default input min and max
  • #6395: NI DAQ USB 6218 AD Converter channels 9-16 can't be used
  • #6397: How to dirrectly reference from the Main Template to a Keyword for a certain test
  • #6398: Driver: Tektronix TDS2024C Oscilloscope
  • #6399: Driver: Tektronix AFG3252 Signal Generator
  • #6400: Driver: IFI ST181-10 Amplifier
  • #6403: Ability to use the FSV-3 Analyser controlled as powermeter in zero span mode
  • #6405: ARFI7000 is not reading probe values
  • #6410: Driver: ETS-Lindgren 8000-053 amplifier
  • #6411: Driver: ETS-Lindgren 8000-034 amplifier
  • #6412: Raise an error when R&S NRP-Z55 is disconnected during a test
  • #6418: R&S FSV 40 Error -222: Data out of range DISP:TRAC:Y:RLEV -10 DBM
  • #6426: Configurable Switch Matrix isn't correctly saving settings when user configured commands of During and/or After Test are cleared
  • #6428: Device driver Check is erasing the selected correction file(s) in the device configuration screen
  • #6432: Device drivers that are using GPIBRS232 should be converted to panels
  • #6436: Selection of a correction file in a device driver configuration is not working
  • #6438: Default frequency range of the EMCO / ETS-Lindgren antenna 3117
  • #6439: Driver: All ETS-Lindgren 8000-series amplifiers
  • #6442: What does the NRP settling time does?
  • #6448: Correct frequency range of the ETS-Lindgren 8000-034 amplifier
  • #6451: Frequency up / down for UFA calculation is not working
  • #6453: Uniform Field Area (UFA) calculation should trigger a default auto-layout when calibrations are added or removed
  • #6454: Not possible to use CAL files for the UFA when it contains different test distance
  • #6455: Warnings related to wxEXPAND are shown when a wxWidgets dialog is shown
  • #6459: ETS-Lindgren 8000-053 Device Not Connected
  • #6462: How to set the RBW when the R&S FSP 40 is used as powermeter?
  • #6465: Driver: ETS-Lindgren Antenna series
  • #6467: Driver: R&S FSIQ 7
  • #6471: 'Decrement' should be the default value for the PowerStep setting of the Amplifier Linearity test
  • #6472: Settings that are normally protected for the administrator, can be changed when the dongle is not present
  • #6474: After zooming in a graph the graph axis is no longer linked to center and span
  • #6476: Save the configured Auto-Layout settings for the Uniform Field Area (UFA) calculation config
  • #6477: Insert Row in a Correction file is not working if no row is present
  • #6478: A new correction file should have 1 row by default
  • #6479: A new row should be added to a correction file when the 'TAB' key is pressed in the last cell
  • #6487: Driver: EUT Controller: Generic TCP/IP Status interface
  • #6488: Python program to test/verify the Generic TCP/IP Status inteface
  • #6491: Driver: Frankonia EMCL-20
  • #6493: GPIB address of Frankonia FC06 cannot be changed
  • #6504: Project: Remember which graphs should be shown
  • #6505: Propose best implementation to remember graphs to be shown
  • #6527: Ability to specify a frequency depending RBW for the R&S ESI Powermeter
  • #6536: Unit-test for the C++ CenterSpanStartStopFrequency class
  • #6537: In the testsite window, 'save as ...' should show the original name + ' - Copy' as the new suggested name
  • #6571: Remove Row of a correction file selects the first row if the last row was selected
  • #6572: Show a message with the used coupling value for the virtual coupler
  • #6577: Project: Telefication: Substitution measurement investigation
  • #6580: Showing the configuration window of R&S NRVS AD-Convertor crashes
  • #6586: ETS-Lindgren HI-4422 VI_ERROR_INV_PARAMETER: Invalid Parameter error
  • #6609: Update the splash screen logo of ETS to DARE!! Instruments
  • #6620: Driver: Frankonia ALX-4000E / AXL-80
  • #6624: Driver: Frankonia FLG-70C / FLH-200B1
  • #6627: Make StandardPreAmplifer device drivers Configurable
  • #6657: grid color always black
  • #6664: Driver: R&S ESRP7 as powermeter
  • #6717: Zero button should be shown for the FieldSensor Virtual Instrument
  • #6726: How do I configure the RPR3006W power meter for remote control?
  • #6735: Also show a magnifier button after the selection of the CONFDVDR directory
  • #6796: Report generator code to retrieve the 'Device driver versions'
  • #6847: General working and use of Main and test specific template with the Report Generator
  • #5999: Mark the 'Continuous Measure' button in a different color when it is activated
  • #6295: When note window is opened the focus or cursor is not set to the text field by default
  • #6368: Duplicating more than 100 tests in a sequence takes a long time
  • #6369: Duplicating a test in a sequence file, doesn't mark the sequence file as changed
  • #6370: Radio buttons of Conducted Emission Manual Mode traces are swapped
  • #6387: It is not possible to select multiple peaks and therefore needs to select peaks one by one
  • #6388: Adding new peaks is resetting the peak lists selected column information
  • #3324: Linearity check for calibration (16 points, 5.1 dB down)
  • #4690: Language error: initialisation successfull <=> successful
  • #4772: Add a 'Pause' as a possible action
  • #5004: A warning should be shown if the AD-Channel maximum and minimum are the same
  • #5250: Change format of graph export per default
  • #5513: Directories configuration of latest version is interfering with older RadiMation version
  • #6168: Harmonic Graphlines have unlogical names
  • #6190: Add a general notification icon on all the Multiband configuration windows
  • #6193: Change the 'Change' button to 'edit' including a picture button.
  • #6196: The Version number in the shared Libs DLL's are not updated
  • #6197: Add a 'Remove' option in the right click menu of a device in the TestSite configuration window
  • #6201: The table with measurement data is not shown when the Harmonic test data is opened
  • #6242: Adding a 3rd amplifier to the amplifier control panel does not update the amplifier control panel correctly
  • #6292: Rename tabs on the testsite configuration: 'Standard 1' to 'Devices 1' and 'Standard 2' to 'Devices 2'
  • #6300: Enhanced Status Window parameters are not shown
  • #6326: Add more low baudrates: 1200, 600, 300, 50 Baud
  • #6335: 'Advanced Information' window should be renamed to 'General Information'
  • #6357: Regex returns 0 for notations with a space between +/- sign and the actuall number
  • #6401: Configurable Amplifier should have wait options after sending power on (for warming-up) and off (for cooling down)
  • #6408: Amplifier Slope verification for Conducted Immunity
  • #1106: Directory names in the configuration should be shortened if they don't fit in the listview control
  • #2731: Address information of the customer, manufacturer and test-site should be able to be copied from or pasted to the clipboard
  • #2860: The amplifier control window is displaying nothing if no items are inserted
  • #4538: Turn during measurement explanation
  • #4805: Data export from menu REPORTS-EXPORT is not working
  • #5692: Driver: 3115 Double-Ridged Guide Antenna
  • #5877: Proceed to include some proposed wiki pages for inclusing in manual
  • #6071: Very slow band switching in Multiband Immunity (Levelling problem of Power Delivery Test)
  • #6277: The 'cancel' button should not be shown when an engineers is removed
  • #6283: Broadband units (like dBuV/m/MHz) are not possible for traces
  • #6512: Use the Microsoft Visual Studio 2015 compiler
  • #6521: Amplifier Linearity test requires an antenna in the selected testsite for Conducted Immunity
  • #6546: New device drivers is raising Description for this error is not available error 536879923 during startup
  • #6548: Minimum supported Windows version should be changed to Windows 7 SP1
  • #6585: NRP Z55 zero operation took longer than 60 seconds error
  • #6588: RegisterDeviceDriver too slow. It takes a second.
  • #6605: Is the Ines USB-GPIB-2 card supported?
  • #6606: Is the Prologix GPIB convertor supported?
  • #6610: R&S ESRP 7: Not all bytes are written to the GPIB-Board
  • #6645: How can I set the resolution to logarithmic stepsize?
  • #2550: Menu option that starts NI I/O Trace
  • #5091: Debugging of device drivers through DDLOGGER.DAT should be simplified
  • #5693: Driver: Agilent E7402A Spectrum Analyzer
  • #6008: Possibility to temporarily disable system error checking in a device driver
  • #6119: Error that the frequency of an already used testsite is not suitable
  • #6384: How to use the R&S ESCI 7's built-in pre-amplifier in 30MHz-1Ghz range
  • #6435: Is it possible to change a correction of an already performed MB emission test?
  • #6445: Keywords ||DATE MEASUREMENT|| and ||SETUP TYPE|| do not work anymore
  • #6447: Slow powermeter measurement of the R&S NRP Z91
  • #6533: PDF version of the RadiMation manual is 55 MB
  • #6551: Enables users to easily send Error Reports with RadiLog
  • #6553: Add RadiLog messages to the R&S NRPZ powermeter device driver
  • #6567: Include a menu entry in the main menu to start the RadiLog
  • #6597: R&S NRP-Z91 cannot be used in Powermeter Virtual Instrument
  • #6598: Checking a R&S NRP-Z91 takes forever when it is not connected
  • #6608: Add RadiLog messages to the USB HID device stream
  • #6653: Sending an error report causes an error report
  • #6655: Output parameters are not shown in RadiLog
  • #6658: Updating Error Report Window
  • #6659: Added button to ReportStauts error in RadiMation
  • #6666: Driver Teseq PMU 6006 powermeter
  • #6721: Not possible to measure the average field probe value during Multiband
  • #6722: RadiLog crashes with a 'startIndex cannot be larger than length of string'
  • #6778: More lines are included in the graph in a report than requested
  • #6784: “hot-key” to export the numbers from the harmonics + linear graph EUT-Calibration module
  • #6823: Do I need correction files in RadiMation for powermeters?
  • #1151: Minimum performance level fixed field
  • #1881: Graphs for applicable signal/forward/reflected/net power need to be added if a related input is measured
  • #1945: Generated Power in Multiband immunity is not limited by the allowed range that is configured the AD Channel
  • #2869: Multiband test does not allow the user to select only the reflected power meter as an input
  • #3605: Multiband minimum performance is not possible
  • #4090: RI multiband minimum performance not working
  • #4576: Auto ranging of the HI422 is not working correctly
  • #4821: Driver: Tektronix 3000 for fixed voltage test
  • #4873: Wrong reading of TDS 3054B scope
  • #5323: Pre measurement detector suddenly turns other detectors on or off
  • #5572: Use maximum performance level as new start level at next frequency
  • #5880: Button to show overview of Calibration Expired (activated) devices
  • #6125: Possibility to set the used type of average detector
  • #6163: Configurable AD converter measurement always returns zero
  • #6233: Control the oscilloscope Tektronix TDS 2000 Series by USB
  • #6268: Specify CW instead of NONE, if no modulation is applied
  • #6385: Add report generator keyword which only outputs the date
  • #6631: Driver Polarization of the RadiField
  • #6640: Driver Configurable antenna tower device driver to control polarization
  • #6712: Switch the external 40 dB attenuator used with Keysight 33521B
  • #6716: How to configure the increase of the power during regulation?
  • #6731: Allow that the available columns for the device driver can also be selected in the testsite configuration window
  • #6737: Driver RadiField 2003A/2006A/2003B/2006B
  • #6738: Windows 10 USB drivers for Radi-products
  • #6739: Hide the white area in the Virtual Instrument window
  • #6742: Agilent N9038A Average measurements taking longer than expected
  • #6762: Ability to select another detector in the R&S ESI powermeter
  • #6763: Using the R&S ESI 40 scanning receiver as a powermeter raises the error "BAND:MODE:FFT OFF"
  • #6764: Tektronix AFG 3252 Timeout while waiting for *OPC command
  • #6770: RadiField errors from the RadiCentre are not raised
  • #6771: RadiField Polarization driver should have 'ignore height change' ticked by default
  • #6774: R&S NRP-Z55 returns a -10000 dBm value when the powermeter returns a 'NaN'
  • #6779: How to perform a Radiated Immunity MB threshold level test
  • #6789: VSWR testlevel is not shown in the TestLevel inputs box
  • #6794: Multiple tests with same TSF name difficult to include in RG
  • #6801: Graph customization settings are not used during printout
  • #6806: A lot of 'Handles' are used by RadiMation
  • #6809: Can't find device driver for RadiField 1009B
  • #6812: Add new Reseller to the Sentinel Key program for Dongle programming
  • #6819: Tektronix TDS2024 is not correctly controlled
  • #6835: Can deleted measurements be recovered by RadiMation?
  • #6836: Is Windows 10 supported?
  • #6838: How to see more details of the tweeted improved RadiMation functionalities?
  • #6848: RPR3006W is not showing powermeter values when used as virtual instrument
  • #6858: RadiLog ReportError should include the RadiMation global event log of that process
  • #6867: Is it possible to add more than one amplifier to a test site?
  • #6881: Is the device driver for the R&S NRP-Z51 powermeter available?
  • #2848: Regulated testlevel should be above requested testlevel if testlevel could not be regulated within the tolerance
  • #3962: A limit in a Multiband CI test is only checked when power is limited by amplifier limitation
  • #3963: Ramp method in CI Multiband doesn't remeasure the generated voltage
  • #4264: Field level is less than set
  • #5371: Initialization of Prana AP32 DR216 Amplifier is always successful
  • #5978: Driver: Prana DT70D Amplifier
  • #5988: Driver Teseq ITS6006 for IEC61000-4-3 & CISPR11 as Signal Generator
  • #6134: Driver: Teseq ITS6006 for IEC61000-4-3 & CISPR11 as Power meter
  • #6214: Driver: Prana DP600 amplifier
  • #6253: Driver: Prana DT70S amplifier
  • #6288: Driver: Prana UX55 amplifier
  • #6318: Driver: Prana SV70D amplfier
  • #6319: Prana LT320D amplifier doesn't work
  • #6358: RadiField and RadiGen doesn't switch to local at the end of a test
  • #6374: Driver: Prana MT700 amplifier
  • #6396: NI DAQ USB 6218 AD Converter read values are delayed
  • #6425: Driver R&S NRP-Z91 controlled by SMB100A using USB
  • #6460: Driver: Prana MT400 amplifier
  • #6489: Check if the HI-6005 fieldprobe is working correctly in combination with the EPI1001A
  • #6625: Driver: Frankonia EFS-10 / EFS-100
  • #6641: Driver: Control the polarization on the antenna using an RadiCentre external relais card
  • #6662: Virtual Instrument for the field strength sensor
  • #6777: Amplifier Linearity / Uniformity test different result at 1 -6 GHz
  • #6787: Agilent 4403B Spectrum analyser Device Not Connected error
  • #6863: Explanation for the use of correction factors for a Current sensor
  • #6864: DVDRSYS.DLL cannot be loaded anymore from new device drivers
  • #6886: Driver: Bonn Elektronik BLMA 4060-40
  • #6901: How to create a correction factor using the unit of transfer impedance in dBOhm
  • #6909: Why is a window with a description and value text is shown during the test?
  • #4575: Connecting another RadiPower Virtual instrument when another RadiPower is continuously measured, corrupts the data of the continuously measured RadiPower
  • #5455: Error wrong argument during Burst test
  • #5471: Burst measurement Unhandled exception Object reference not set to an instance of an object
  • #5876: App. Note 100: Enhanced Status Window usage and description included in the manual
  • #6095: Driver: Bonn Elektronik BTA 0122-3000
  • #6441: Frankonia FC is raising an -101 error during test initialization
  • #6473: Cannot access a disposed object frmVIPowerMeter
  • #6623: Driver: Frankonia ECU-3 / ECU-6
  • #6713: Driver Keysight 33521B Signal Generator
  • #6714: How can to get some specific trace data in the graph?
  • #6865: Implement retry of Software Update used for RadiField amplifier firmware updating
  • #6878: Comm failed with Powersensor PMM6630
  • #6888: Driver: Rohde & Schwarz ESR 26
  • #6890: Reportstatus of Kom ik hier? is shown during RPR3006W
  • #6898: EventLogData in list controll to be made possibly visible in RadiMation.
  • #6899: Event Window
  • #6913: EUT window is not correctly sized on 1024x768 beamer
  • #6939: Lasercode to activate the RadiSense fieldsensor laser inside the RadiCentre
  • #6942: Configurable AD-Convertor for asynchronous data
  • #6592: Update to .NET 4.6.1
  • #6954: Prana AP32DR312 amplifier serie is infinitely polling status when warnings are returned
  • #6962: Configurable AD Convertor device driver cannot interpret multiline result
  • #6965: Add ability to return the RAW AD Converter value
  • #6556: Update the CD Start menu for 2016.1
  • #6558: Update version and copyright years to 2016
  • #6983: Empty tabs and no labels are shown after fresh installation
  • #6998: Data table from Multiband Immunity in the report generator is always using time interval mode
  • #7003: Device check of the R&S SMB100A is unsuccessful
  • #5587: Old LLF is not removed and not replaced with newly added LLF
  • #5969: R&S ESU EMI receiver is only set to integer frequency values
  • #6393: Graph is covering a rang and analyser is performing a test outside the specified bands
  • #6464: Automatic search of highest peaks is changing graph shape
  • #6466: Driver R&S FSL
  • #6470: Driver R&S NRP2 powermeter
  • #6518: FSU 3 error -200 Option ot available INP:PRES:STAT ON during test initialization
  • #6723: Broadband disturbances are showed as peaks
  • #6804: AD converter values of older tests are not correctly showed in latest versions
  • #6903: Add an additional 'Maximum cable length' field for a cable in the EUT
  • #6904: Add a note field to a cable
  • #6912: RadiLog icon disappears when pinned to the taskbar
  • #6972: RadiLog is not able to write to temporary directory
  • #6981: Setup program doesn't check if .NET framework 4.6.1 is installed
  • #6985: Advantest TR4172 as powermeter is not correctly measuring
  • #6986: RadiLog icon disappears when pinned to the taskbar
  • #6988: R&S FSU: Not possible to select 50 MHz RBW
  • #6991: How to determine the compression level using a constant output power test
  • #6992: Software update will crash RadiMation when a connection error is found
  • #6993: RGN Setting the output level raised an error
  • #6994: R&S FSU undefined header -113 INP:TYPE INPUT1 error
  • #6999: Time interval of table data from a multiband immunity test in the report skips rows if a large delay was present during the test
  • #7005: Limitlines are not shown when old test results are opened
  • #7008: Reflected power too high
  • #7011: RGN software update panel should be hidden
  • #7012: Implement checking of system errors for RGN
  • #7014: Report Generator can be used without a license
  • #6311: Crash when maximizing the MB Emission test result window
  • #6333: RadiMation crashes when maximizing the multi-band emissions results screen
  • #6430: Radimation crash if radiated emission window resized during measurement
  • #6686: Driver Luthi FT/FTC series absorbing clamps
  • #6715: Run-time error 5 procedure call or argument is not valid in RADRESRC.DLL
  • #6896: Error timeout with Maturo MCU controller
  • #7017: SYST:ERR -222:Data out of range for RadiGen
  • #7020: Limit lines are not shown automatically at the end of the test
  • #7022: Maximum cable length is not included in the ||EUT|CABLE TABLE|| in the report
We also include several improvements and new functionalities in version 2016.1.3, the most important improvements are:
  • Amplifier Linearity check according EN 61000-4-3 and EN 61000-4-6.
  • RadiLog communication monitoring.
  • Graphs will remember if they are shown, and will then automatically be re-shown.
  • Multiband Immunity Minimum performance testing.
  • Several user interface and usability improvements.
  • Report generator fixes
  • Better control of measurement equipment.
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2016.1.
The new 2016.1.3 release of RadiMation can be downloaded from the DARE!! web-site: Image
We always advise to thoroughly test EACH new RadiMation software version to determine if it works correctly in your situation with your equipment, before you use it for daily measurements. This is even a requirement for all ISO 17025 accredited test-labs. To enable customers to validate new software versions before they implement that new software version, we even made it possible to install multiple versions of RadiMation side-by-side on a single PC. This side-by-side installation is normally not possible with other programs but is especially implemented in RadiMation.
