(#4726) Graph Export functionality
Via Radiated Emission > Graph > Export a graph can be exported as example to *.csv file format. You can only export one graph at a time.
1st question:
Is it possible to export several graphs within one *.csv file (using two or more colums).
2nd question:
"Max peak correction" is total correction of all transducers. Is it possible to split this total correction in seperate corrections of each transducer within a *.csv file.
Re: Graph Export functionality
Currently it is only possible to export one graph line at the time, but I understand the question.
It would indeed be a good improvement to export multiple graph lines at once at the 'Select the graphline to export' window.
This is saved in our database with reference to item #4726: Possibility to export more then one graph trace.
2.
Can you send a test data file to our support department, which contains information about multiple corrections as an example.
We can investigate the possibilities for this wish for new functionality and based on this provide you with additional feedback.
