New version: RadiMation version 2016.1.13
We have released an updated minor version of RadiMation software, which includes several new device drivers and some small fixes for problems that have been detected since the release of the 2016.1.12 version.
The following issues are fixed in this 2016.1.13 version (compared to the 2016.1.12 version):
  • #3168: Is amplifier protection working in a multiband immunity test
  • #3517: Radiated Immunity: Level is going too high
  • #4397: Forward power protection file for an Amplifier is ignored if power is already limited
  • #4586: Amplifier limit completely ignored
  • #6304: Reference level should be requested to ensure a correct calculation of the measurement value
  • #6855: Limitation of a Multiband Immunity test on the current is levelling just above the limit
  • #7437: R&S FSEK 30: Function not available;BAND:MODE:FFT OFF
  • #7468: Quasi peak measurement of Analyser sometimes has a difference
  • #7634: R&S FSEK 30: Function not available: FFT OFF
  • #7786: Regular expression of RFS2006B antenna tower is incorrect
  • #7787: Driver Vectawave VBA230-22 and VBA1000-150
  • #7789: Advantest TR4172 Not all bytes are written to the GPIB-Board within the timeout period
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2016.1.
The new 2016.1.13 release of RadiMation can be downloaded from the DARE!! web-site: Image
