Add Coupling and decoupling network driver
Rdammert
Post by Rdammert »
I want to add a CDN driver for use in a Conducted Immunity test. However, this CDN is not found in the available driver list. How can i add a new CDN driver for use in Conducted Immunity testing?
Re: Add Coupling and decoupling network driver
If you want to add a CDN driver which is not found in the available drivers list for use in Conducted Immunity testing.
You can add a new driver by hand, to do this follow the following steps:
1) go to Devices -> Configure -> Device Drivers.
2) Select Injection devices as the device driver type.
3) Press add.
4) Search for the configurable CDN, and add in the the list of drivers.
5) Double click on the new added configurable CDN driver, and open the advanced settings of the driver.
6) On the advanced setting screen, fill in the frequency range and resistance of your CDN.
7) Close the advanced settings and driver window.
8) Add the new driver to your test site
9) verify the correct working of your new added device.
